Diff cover question
Old May 1, 2007 | 11:40 AM
jared1843's Avatar
Also: I have the Limited Slip rear differential. Is there something specific with it that requires a certain type of gear oil?
Old May 1, 2007 | 12:01 PM
gergy9's Avatar
Actually, DO NOT fill your new aftermarket diff cover up to the bottom of the fill hole especially if it's located higher than the factory location. By doing this, you will have over filled your diff and the gear oil will be sitting in-line with the axle vent tube. And, once you start driving around, you will find that your gear oil will start pumping out of this tube and make a stinking mess of your passenger side rear fender well.
What you need to do is just fill your diff to the required amount as stated by the FSM which is about 2 quarts. For detailed instructions as to what to do, click on the link below to see my write-up. Granted, this was done on a TJ but it really is all the same stuff
Dana 30 Differential Cover Installation Write-Up
Dana 44 Differential Cover Installation Write-Up
WOL i will have to slightly disagree with you here. Because the aftermarket cover will be larger you would fill to the HEIGHT of the OEM fill hole. If you only fill to FSM stat you may not have enough. Just my Opinion.
And Yes i am one of the idiots that found this out the hard way. Now i blow oil everywhere i go... Need to find time to drain a little bit out.
Old May 1, 2007 | 12:04 PM
onsafari's Avatar
Hmmm never had a problem with gear oil coming out of my breathers before. Either with my TJ or the JK stock or lifted. I will say it is a must to overfill you diff once you lift it and rotate the pinion angle up. That's why the hole is higher than that of a factory cover. Gotta keep them pinion bearings happy ya know!!!!!
Old May 1, 2007 | 12:12 PM
gergy9's Avatar
Could you please explain rotating the pinion angle up? Why? Is this something you need to do when you re-gear?
Old May 1, 2007 | 12:17 PM
onsafari's Avatar
No...rotating a pinion only occurs when you lift the vehicle. It helps to get the driveshaft back in line with the differentials and helps cure any driveline vibrations.
Old May 1, 2007 | 12:42 PM
SCF's Avatar
SCF
Hey Eddie,
I have a RockCrusher D44 diff cover that I picked up when I had the TJ. Never installed it, and it's sitting in my garage whispering..no..calling..no..SCREAMING my name now. Correct me if I'm wrong, but the bolt pattern for the JK D-44 is the same, right? This should bolt right up.
Old May 1, 2007 | 12:45 PM
Piginajeep's Avatar
Originally Posted by SCF
Hey Eddie,
Yes, it'll bolt up... shave the rockcrusher off first...
Old May 1, 2007 | 12:53 PM
wayoflife's Avatar
JK-Forum Founder
Nope. The synth oil will have the friction modifire you need already in it
Old May 1, 2007 | 12:58 PM
SCF's Avatar
SCF
Ok, just got off the phone with Grant from Rock Crusher.
Like answered above, it will bolt right up. And it will require more fluid than a standard cover. His rule of thum is to take your index finger and poke it all the way into the hole, and point down. The fluid should JUST touch your finger tip. Also he stated that you will need 1/2litre (500ml) more of fluid than stock. Bloke is an Aussie, hell of a guy too!
Old May 1, 2007 | 01:02 PM
wayoflife's Avatar
JK-Forum Founder
Hmmm, yeah, I can see that maybe if the cover you have does in fact allow you to hold a significantly larger capacity of fluid. But, are you 100% sure that it does? What are you basing this on? Just curious.
EDIT: Never mind, SCF just answered my question
LOL!! Don't feel bad, I've been one of those idiots too
