Diff cover question
Old May 2, 2007 | 05:57 AM
  #31
BLKRUBI's Avatar
Not to hijack, but will all current Dana 44 diff covers fit the JK (front and rear on a Rubicon)?
Old May 2, 2007 | 07:33 AM
  #32
BLKRUBI's Avatar
Originally Posted by PhilD
Yes, but there may be clearance issues with the track bar with some covers.
Stock, both my front and rear track bars touched the upper fins on my RockCrawler covers. With 4" lift, the front is clear, but the rear still touches the upper fins.
I should add that they do not make contact while driving on-road, only when getting flexed up.
That's what I needed to know. Thanks Phil.
Old May 2, 2007 | 05:24 PM
  #33
gergy9's Avatar
Pretty Picture Time!
Old May 3, 2007 | 04:46 AM
  #34
captsam54's Avatar
Hey.. Great pic's, I need to geta set of those.. I noticed you haven't fixed your exhaust yet... Got mine done last mon-tues, for $180.00
Old May 3, 2007 | 06:48 AM
  #35
gergy9's Avatar
What did you have done?
Old May 3, 2007 | 07:39 AM
  #36
captsam54's Avatar
I went to my local muffler shop and had them cut out/off my oem muffler, and installed a small Magnaflow under the drivers area, and then welded an extension tailpipe on ..About 8 more ponies That and if you do a air box kit.. (I put in an AEM).. even more ponies.. You can defiantly tell the difference, and get better mpg. See my gallery pic's and type in Magnaflow in the search thread to see all the posts and pic's regarding this mod.. Good Luck..
Old May 3, 2007 | 08:29 AM
  #37
droldz's Avatar
On the subject of covers, I have a question.
The 44 on the frt is a HP. Why does it look like it has a low pinion cover on it?
I have a HP cover off a ford axle and the fill hole is higher.:confused:
Old May 6, 2007 | 07:02 PM
  #38
Foo's Avatar
Foo
I'm really thinking about this as well, but I think I'll end up going with Rock Rings. No worries about fluid level, and no need to drain, re-fill.
Old May 6, 2007 | 07:10 PM
  #39
TEV's Avatar
TEV
you need to change your differential fluid every now and then anyways. When I drained mine it had a lot of slush. Replacing it with the synthetic is always a nice upgrade as well. Go with amsoil tho, stay away from the royal purple junk. :toung:
Old May 7, 2007 | 04:11 PM
  #40
Ryanm's Avatar
Will the Warn Diff skid plates work with aftermarket upgraded Diff covers? Specifically the Dynatrac, Rockcrusher or Solid Diff covers?
