Diff cover question
Old May 7, 2007 | 06:57 PM
  #41
jared1843's Avatar
TEV: What is wrong with Royal Purple gear oil? I just bought a load of it to use when I put my new covers on....
Originally Posted by TEV
you need to change your differential fluid every now and then anyways. When I drained mine it had a lot of slush. Replacing it with the synthetic is always a nice upgrade as well. Go with amsoil tho, stay away from the royal purple junk. :toung:
Old May 7, 2007 | 08:08 PM
  #42
Living Still's Avatar
Originally Posted by Ryanm
Will the Warn Diff skid plates work with aftermarket upgraded Diff covers? Specifically the Dynatrac, Rockcrusher or Solid Diff covers?
Wayyyyyyyy overkill. You can pound on any after market differential cover for a lifetime and still not need that kind of protection. If you hit something hard enough you may here some disturbing sounds, but I guarantee you that the damage will not be to the diff. Run something like a 37" tire and maybe you'll be hearing your housing bend after some air time.
Old May 8, 2007 | 04:30 AM
  #43
captsam54's Avatar
Really.. I hear everyone loves that stuff.. I use amsoil in my Towboat and truck (now Jeep), and Harley synthetic in my bike.. I hadn't thought of usuing amsoil in the diff's.. Is there a #, or just gear lube?? thanks
OH and I am going with rock rings too.. RED ONES..!!
Old Oct 23, 2007 | 05:08 AM
  #44
Piginajeep's Avatar
Originally Posted by TheDog218
How do you do this "and rotate the pinion angle up" ???? Is there a write up on this ? I lifted my jk 3 1/2 is this something I need to do?????
Adjustable control arms
Old Oct 23, 2007 | 05:50 AM
  #45
wayoflife's Avatar
JK-Forum Founder
As Piginajeep said, you will need adjust upper rear control arms to do this and it is needed to be done if you have an aftermarket double cardin u-joint style drive shaft. Click on the link below and see step #64 to see how to do this:
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Oct 24, 2007 | 05:29 AM
  #46
scottcarp's Avatar
Default Why not change factory diff fluid this quick?
Well, typically I would say you should change it out at about 500 miles...
I can guess why you'd change the fluid after installing new gears, but what is it about the factory gears that the Maint. Schedule doesn't list it until 15K miles? Should I have done it then?
Old Oct 24, 2007 | 05:50 AM
  #47
wayoflife's Avatar
JK-Forum Founder
Honestly, I've always wondered that as well but in answer to your question, yes, I would change out your diff fluid at the recommended 15k.
