Disconnects
Old Feb 26, 2013 | 08:44 PM
Ironhead920's Avatar
Default Disconnects
Listen im a newb… i love the opinions here… so here we go.. I've got the aev 3.5 on 35" Someone mentioned today about getting disconnects. I see there an inexpensive part. Please help me understand them and which product would help me out here.
2013 sport
Old Feb 26, 2013 | 08:55 PM
joshsolo's Avatar
They help with articulation of the axle. Like when you'll see guys "flexing" or having one wheel up on a tall object and the other on the ground. This will help with more uneven terrain when you go wheeling. Keeps the jeep level
Old Feb 26, 2013 | 09:03 PM
shockwaveaz's Avatar
Most will work fine for you. They just makes it easy with the quick discos. All they do is disconnect the links on your sway bar to allow more flex/droop. You can do this with a wrench and zip tie them out of your way for free when on your next wheeling trip to try it out. Just don't run that way on the road... Too unstable for my taste. Makes a big difference.
Sent from my Galaxy Note 2
Old Feb 26, 2013 | 09:18 PM
And this is ok? Just unbolt them and zip tie them up and out of the way? And before gettin back on road bolt them back up? Everything will line right back?
Old Feb 26, 2013 | 09:40 PM
Darkjk's Avatar
I want to make my own disconnects, and I was wondering g what the bolt sizes are for them? I know I could just go look, but I was wondering if anyone could just give me some info. Also, what grade is the hard ware used?
Thanks!
Old Feb 26, 2013 | 09:59 PM
TURTLECON's Avatar
Yeah most unbolt the lower mount, then raise the link and ziptie it out of the way along with the swaybar. When you go to bolt them back up, you may need a buddy to push down or rock the jeep to get the link to line up with the bolt location. It also helps to turn the wheel towards the side you want to remount for more room to maneuver and if you're on a slight downslope it's easier to re-align. Once you get the one side done, the other usually bolts up fairly easy.
Tip: Keep the swaybar horizontal when you ziptie it in place... prevents the possibility of puncturing the tire when flexing. It's rare, but it happens.
Old Feb 27, 2013 | 03:10 AM
sgtkersh's Avatar
The teraflex ones are about $130. They are really nice since they come with a perch to fasten them to the upper body mount when you disconnect the sway bar.
Sent from my iPad using Tapatalk HD
Old Feb 27, 2013 | 03:44 AM
cis911's Avatar
I figured all quick disconnects work the same so I got the lowest priced discos the rough country ones. they did their job on the road (connected) with my 37 s http://www.roughcountry.com/jeep_xtras_1146.html
Old Feb 27, 2013 | 04:29 AM
Offroad_Elements's Avatar
Former Vendor
TeraFlex disconnects are what I run. Greaseable ends make a big difference
Old Feb 27, 2013 | 05:00 AM
c4bus's Avatar
I just ordered the terra flex ones. I disconnected a few times manually and it was a B. two wretches, 10 minutes. I can't wait til I get the quick discos. I'll update on Friday when they're installed.
