Do I even need spacers?
Old Mar 25, 2014 | 01:14 PM
wpmvii's Avatar
Default Do I even need spacers?
Hey all... Thanks for your patience and advice... I've got a 2011 JKU Sport that I'll be using for short trips to town and for navigating pot hole filled roads... ahh spring! But next to no off-roading (honesty is the best policy). I'm looking to add some wheels & tires for looks. Specifically:
Procomp 17's 7069-7973 w/
Procomp MT2's 33's
I read Dirtman's thoughts on lifts - which was very insightful & that has me thinking that even a 2.5" lift is something I could/should add down the line - if/when I get more aggressive with my use...
So the question becomes - running on a stock suspension - do I even need to put in a spacer kit to fit those tires on my Jeep? Or could I get away with a little bit of trimming to the fenders (and this pinch seam i hear so much about)?
Every shop I talk to wants to sell me $1000 worth of parts and install before i drop another chunk of cash on wheels and tires.
Brand new to this stuff - so I appreciate the help and advice.
Old Mar 25, 2014 | 01:22 PM
Billbikes's Avatar
With 33's you rally don't need to lift at all, maybe some trimming, but if you're not really going offroad, you "may" get away with not trimming. You could definitely get away with a leveling kit. The Teraflex spacer kit is only $136 and is pretty easy to install.
Old Mar 25, 2014 | 01:52 PM
BlackRockBurner's Avatar
If you go with skinny 33's all you have to do is adjust the steer stops. I ran 275x70x18 for over a year, then later added wheel spacers prepping for a 2.5" lift.
Old Mar 25, 2014 | 05:05 PM
DKehler's Avatar
I ran 33's with no lift for a while. my rims had 4.5" of B.S. and the only thing I rubbed was the air dam while in reverse under throttle. I put on a 2" spacer lift and stilled rubbed almost as much. A small trim with a razor knife fixed that.
Old Mar 26, 2014 | 04:24 AM
wpmvii's Avatar
Default Sounds like a plan.
Thanks guys -
I think I will give it a whirl... Drive with them for a while and see if I need to trim. If that doesn't fo it I can always grab a spacer kit and pop them on. One slight follow-up question. I was looking at the MT2 305/65R17's or the 285/70/R17... Are we thinking the 305's would be too wide? or is it 6 to one - half dozen the other?
Old Mar 26, 2014 | 09:33 AM
Mschneid's Avatar
Originally Posted by wpmvii
Thanks guys -
First off, Welcome. Just be careful, in PA you can't stick out past the fender flares for inspection. I am really close to sticking out with my 285/75/17 but that's because of the back spacing on the wheels I bought (wish I could remember what it was).
