Do I need an alignment?
Old Jan 14, 2012 | 12:28 PM
  #21
JK-Ford's Avatar
The "steer ahead" numbers changed. Is this a reflection on the toe adjustment alone?
What about the secondary angles that I mentioned earlier? Do they not apply. I know that the turning toe could do a lot of damage.
It is "eye opening" that with this particular arrangement, toe is the only adjustment. I have always planed on CA's for my lift anyway. I'll have to go back and read the write-up again. But I thought that it was mentioned that the "tape measure adjustment" was recommended as a temporary fix untill a profesional alignement could be performed. I still think that the OP did the right thing by having an alignement performed.
Old Jan 14, 2012 | 12:34 PM
  #22
newbiejeeper's Avatar
Based on my caster I will be adding LAC arms.
Old Jan 14, 2012 | 01:14 PM
  #23
nthinuf's Avatar
Originally Posted by OverlandJKU
Wow calm down before you blow an O ring. Please point to anything in my post that is wrong... And I will correct it. First mention of stock components was your response, which I covered with the statement " simple adjustments".... How I feel about cam bolts, and under $300 in ball joints (sorry if you are paying retail) is completely irrelevant, ( I have neither) my point was simply, that cant is too strong a word. I also fail to see where I had any question of the OP's end results....
Way back in post 5? Without adding adjustables, they can't...
