Do i regear or not!?
... There is a whole lot of off base information in this thread.
think of it simply like this. Your gears are additional muscle that you're adding to your drive-train to help move all the additional mass you have added to your Jeep; ie, Larger tires and heavier wheels, bumpers, winches, aftermarket sport cages, tools, people and the list goes on. Re-gearing to a lower, or for these purposes "stronger" gear ratio will allow you to move all that extra weight much easier. Conversely you will have to use more energy to move much faster, say 85 mph or more, but that's the trade off and you said you were okay with that from the outset.
Honestly, other than perhaps cost, there is NO disadvantage to re-gearing. In other words, if you have everything to gain and nothing to lose by going this rout.
and for what it's worth, 4.56's are a waste of time. Some people say their great, but the difference between 4.56 and 4.88 isn't that much and it will be better to have that power than to not and wish you did. My .02
I though I understood gearing until I read this thread. I assumed the sweet spot was the cells on the gear chart shaded in green. For 35s, it shows 5.13s and 5.38s. Am I not reading the chart correctly? Is the tire size manufacturer spec or actual height under load? What is all this talk about anything less than 5.13s for 35s?
For what it's worth, I went with 5.38s to push 325/60s (measure 35 1/4 under load) on a 2010 jku auto. Also have a Ripp Gen2. RPMs at 70 are exactly what the chart says. It drives great on and off road.
Most of the fellas I ride with have gone with 5.13s and feel it was the best mod they did, other than 35s!
Please educate me.
Please educate me.
I run a 2010 JKU with 3.5 inches of lift, 35-12.50 -17 Goodyear MTR KEVLAR , 5:13 Yukon gears, gusseted D30 front. Auto and a Superchip Flashpac with the 93 Octane tune. And it does not hunt for gears stays in OD on inclines as I live in North Georgia. I get average 16-18 MPG. It is better now than it was stock. So my answer to your question is REGEAR you will actually like your Jeep.
I said there are pros and cons. That means in some way NOT regearing is BETTER. And in some ways, it is other way around. Which part of it is hard to understand?
I am broke... so $1,000 for gears may as well be $1,000,000. However- I would be retarded to try to make a few HP with $200 here and there. If I want PERFORMANCE, I have to save up for gears. If I want HORSEPOWER, I'll save $5,000 up for a turbo.
Originally Posted by TheTerminator
Only from a dead stop. After that it should be very close.
Originally Posted by keithvegas
Most of the thread is about a manual trans. The gearing in the transmission is different than auto so the diff sweet spot gearing is different.
Also don't forget autos have torque converters so in no way can you compare autos to sticks in terms of tranny gearing, its like apples and oranges.
The issue was not that someone doesn't want to regear, that's fine bc it's your jeep. But The Terminator was telling people that you do not have to regear with larger tires. Which is misleading. Like I'm gonna be able to put 37's on my jeep with 321's and have no issue. "I just need to learn how to downshift" is what I was told
The actual tire height that you set on your Superchips or Procal should be used in the chart.
