Does this geometry look correct?
Old Dec 16, 2011 | 09:26 AM
  #21
Beast_Beastly's Avatar
Originally Posted by Rock Krawler Suspension
Thanks for the link. I think we figured out most of your troubles via all the PM's. But, like the one person mentioned, you do need to move that sway bar back as well!...
RK
So what was the final fix? Moving the axle forward? Get adjustable spring perches?
I'm getting ready to install RK upper adjustable CA's....trying to help the pinion angle.
I have RK 3.5" springs already installed, RK rear Trackbar, RK LCA's...don't want to run into any problems.
Thanks, Dave
Old Dec 16, 2011 | 09:41 AM
  #22
Gossamer's Avatar
Thanks, Dave
Depends which LCAs you have. Flex or the extended wheelbase version? It was my error in setting up my Flex Version as Extended wheelbase lengths. That coupled with not moving my sway bar back was the majority of my issues. For the bowing springs, it appears that perches will definitely be needed if you push your axle a full inch back.
Rick.
Old Dec 16, 2011 | 02:55 PM
  #23
Rick.
Thanks Rick...I have the LCA's (not extended) made to work with the stock uppers, but now I've installed the 3 1/2 RK springs so I've bought adjustable uppers and I'm gonna see what I have to do to make them work with the lowers I have. I understand I might need to shorten them a little. I just don't want to buy new LCA's as mine have only been on for a few months. I was worried about what would happen once the axle rotates to fix the pinion angle. Sounds like adjustable perches will be the next purchase. And I'll move my sway bar back (that's the easy part).
Thanks again, have fun tomorrow at Mabell
Dave
Old Dec 16, 2011 | 03:18 PM
  #24
Navyvetnorwich91's Avatar
Veteran: Navy
Dave
Dave any chance of you getting out there tomorrow? Even for a little while? Ive heard so much about the "beast".
Old Dec 16, 2011 | 04:58 PM
  #25
Hey Dave, unfortunately I have other plans. I've got to get back there again one of these days
We've got to catch up at some time.
Have fun!
Dave
Old Dec 16, 2011 | 05:06 PM
  #26
Veteran: Navy
Have fun!
Dave
Well have a great weekend then.
