Does a locker improve axle strength?
Old Jan 14, 2009 | 08:54 AM
ucfavenger's Avatar
say i go with an arb or ox front locker (30 spline)...
1. would i buy the same 5.13 gearing as i would have without the locker?
2. are chromo 30 spline shafts available for the jk under these circumstances? Superior, 10Factory?
Thanks again everyone.
Old Jan 14, 2009 | 09:09 AM
Northridge4x4's Avatar
Sponsoring Vendor
1. Yes
2. Yes
David
Old Jan 14, 2009 | 09:19 AM
ucfavenger's Avatar
1. thanks.
2. thanks again.
Todd
Old Jan 14, 2009 | 02:59 PM
ronjenx's Avatar
Originally Posted by SASQUATCH
Lockers definitley do not add strength per say to the axle, but to the internals it can as stated above. I'm sure some of these guys running the Aussie locker, etc will pipe in and help you out on that D30 and what lockers you could use to match your cmoly shafts.
The following will enlighten you a little on differentials in general along with spider-gears..
http://auto.howstuffworks.com/differential2.htm
Sipder-gears
All four gears in the center of the photo are spider gears, although I believe when most people refer to spider gears, they mean only the red ones in the photo. More accurately, the red gears are called pinions, and the gears on the axles are called side gears.
The JK Rubicon lockers have 4 pinions (the red gears in the photo) for added strength.
Old Jan 14, 2009 | 03:04 PM
Sponsoring Vendor
JK Locker and strength used in the same sentence!
Old Jan 14, 2009 | 03:06 PM
ronjenx's Avatar
Well, it IS stronger than if it had only 2 pinions.
Old Jan 14, 2009 | 03:35 PM
Sponsoring Vendor
to be honest MOST of the D-30 breakages i have seen on here have been with a locker in them.......
And I am willing to bet they all were breaking stock shafts.
David
Old Jan 14, 2009 | 04:23 PM
nangulator's Avatar
? HEAAAH ?
Old Jan 14, 2009 | 06:35 PM
ucfavenger's Avatar
good stuff, thanks.
Old Jan 15, 2009 | 06:19 AM
Jeepnboy's Avatar
One more thought...
Adding a locker will definitely put moe stress on the other components and will be more prone to breaking if the compenents are not upgraded. There is no longer an easy escape (the open or spinning wheel) for built up energy when you have a locker. And yes, we have all heard the argument that one with a locker can take it easier with less wheel spin, but this does not hold true in many cases.
