Does this look normal?
Old Aug 23, 2012 | 05:45 AM
Randog's Avatar
Default Does this look normal?
I got talked into these pro Comp Xtreme MT tires. I noticed after the first rocky trial in Big Bear that they stared to "chunk". This is what they look like now after 3 rocky trails, 3 mild dirt trails and 5k as a DD. The 4 Wheel parts guy said its normal; of course. I think not.
Name:	005 (800x600).jpg
Name:	009 (800x600).jpg
Name:	002 (800x600).jpg
Old Aug 23, 2012 | 05:59 AM
Cudda's Avatar
I would think not but
how old are the tires?
Old Aug 23, 2012 | 06:02 AM
wayoflife's Avatar
JK-Forum Founder
Attachment 357261
Attachment 357264
Attachment 357265
yup, totally normal. we ran a set and destroyed them in no time. the xtreme mt's use a soft rubber compound which is great for hooking up on the rocks but, the downside is chunking. you should see what they look like after running out on the razor sharp rocks they have out in AZ as opposed to the round and relatively smooth boulders up in big bear
Old Aug 23, 2012 | 07:08 AM
Randog's Avatar
Originally Posted by Audiodogg
It's fairly common, even though you only have 5-6000miles on them. But I would also check the age of the tire and make sure this isn't premature wearing out due to aged tires vs just the typical little pieces that fall off the tire from 4x4ing.
I assume to check the age of the tire I'm looking for a manufacture date on the tire? Is there a top secret code to decipher once I find it on the tire?
Old Aug 23, 2012 | 07:15 AM
Randog's Avatar
Is there a better choice in a tire? Big Bear is my choice of wheeling areas and I feel that these tires came apart too quickly, I mean 5 days after I installed them and 4 of those days was on the street! I was thinking of the Toyo Open Country MT or the Mickey Thompson Baja ATZ or MTZ.
Old Aug 23, 2012 | 07:23 AM
wayoflife's Avatar
JK-Forum Founder
i've run a lot of tires and swear by toyo's. mickey thompson's aren't too bad either and both will do well in big bear.
Old Aug 23, 2012 | 07:39 AM
Randog's Avatar
Thanks Wayoflife..
Old Aug 23, 2012 | 10:02 AM
NVRDUN's Avatar
My KM2's chunked real bad, even aired down to 10 psi. It was like after every trip more and more tread was chunked off. I wheel in southern Nevada, Arizona and SoCal. I was just in Big Bear last weekend.
That being said, last weekend was my first wheeling trip with my new Nitto Trail Grapplers, and they did not chunk at all. That made me very happy.
Old Aug 23, 2012 | 10:07 AM
LeJerk's Avatar
Thanks for the heads up on how soft these tires are. If those were my tires I would be disappointed.
Old Aug 23, 2012 | 10:13 AM
dman1116's Avatar
Yep, normal, rocks are freaking brutal on tires
