Doors need adjusting after body lift?
Old 02-11-2015, 06:32 AM
RubicAn11's Avatar
Default Doors need adjusting after body lift?
Has anyone had their doors close and make a thumping noise. I added a teraflex body lift( OH NO! NOT A BODY LIFT! .waiting on the suspension so I dont need drive shafts). Now my doors seem thump when i close it. Even my wife noticed it and she never sees anything different or changed on my jeep. Any one have advice and im not talking about taking the body lift back off. Thanks.
Old 02-11-2015, 06:36 AM
dtcercado's Avatar
Interesting I'm going to be installing a 1 inch pa body lift soon hope I don't run into this. Does the door bind anywhere or make contact with anything? Is it both driver and passenger making the noise?
Old 02-11-2015, 06:39 AM
RubicAn11's Avatar
Not binding, but just a thud like its hitting the Jam and moving up instead of just latching correctly the first time.
Old 02-11-2015, 07:01 AM
14Sport's Avatar
Hopefully you didn't twist the body during the install when jacking it up. Did you disconnect or loosen all the mounts before jacking or did you do one side then the other?
Old 02-11-2015, 08:06 AM
RubiKing's Avatar
Did you put a 2x4 between the jack and the body when you installed the BL?
Old 02-11-2015, 08:22 AM
RubicAn11's Avatar
Yes, I did. Followed the directions. Left the bolts just threaded a little.
Old 02-11-2015, 08:23 AM
RubicAn11's Avatar
No sir, should i have?
Old 02-11-2015, 10:16 AM
RubiKing's Avatar
I have done a few body lifts on jeeps and when I install them I put a 2x4 between the jack and the body, that way the pressure is more evenly distributed and it doesn't bend anything.
If you just put the jack strait to the body and lifted it you may have warped or bended something.
Old 02-11-2015, 11:16 AM
RubicAn11's Avatar
I have done a few body lifts on jeeps and when I install them I put a 2x4 between the jack and the body, that way the pressure is more evenly distributed and it doesn't bend anything. If you just put the jack strait to the body and lifted it you may have warped or bended something.
Didn't figure it could be done that easy. I used the rock rails with a high lift.
Old 02-11-2015, 02:40 PM
dtcercado's Avatar
That's what I was thinking of doing. I guess I will use a floor jack with a 2x4. Rubican do you have a 4dr or 2dr?
Quick Reply: Doors need adjusting after body lift?
