Drastically improved my on road manners with AEV brackets
Old Sep 15, 2012 | 11:51 AM
LidLess07X's Avatar
Default Drastically improved my ride quality with AEV brackets*edit* and EVO drag link flip k
So, like the title says, I installed the AEV control arm drop brackets on my lifted JK and wow, what a difference.
My JK is a pavement princess and usually only sees snow in the winter and beach in the summer so flex and ground clearance are of little concern to me. This, coupled with the cost difference of adjustable control arms prompted me to try the brackets. I was all ready to order springs and shocks because my ride was so bad. Not anymore. My JK is a pleasure to drive again.
Old Sep 15, 2012 | 05:10 PM
c17loadmaster's Avatar
Glad it worked out for you. If you want an even smoother ride, there has been nothing but great reviews of EVO's Plush Ride springs. They come in 3 and 4 inch sizes. All can be had for about 400 bucks. I am even replacing my springs soon with them.
Old Sep 16, 2012 | 06:09 PM
LidLess07X's Avatar
Thanks for the tip. I was looking at OME and Bilstein, but will definitely check out EVO.
Old Sep 17, 2012 | 06:06 AM
Black_JKU's Avatar
I was about to
Post this exact same thing today as I installed my brackets Friday.
They made my jeep
Drive CONSIDERABLY better!!
ZERO flightiness, Zero bumpsteer , the jeep now brakes like a sports car... Stays flat as a pancake.
I havd a 2.5 spacer lift. When I hit bumps in the road and even harder impacts offroad.... I barely feel them.... I feel like I installed a whole new suspension under the front.
Very good build quality too!
Instructions sucked though!!!!
I'm curious to see how doing the same thing on the rear would help
Old Sep 17, 2012 | 06:19 AM
Kojack's Avatar
how tall was your lift? how much ground clearance did you loose?
instructions are crappy in general...aev makes excellent products...
Old Sep 17, 2012 | 06:54 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Much of the improvement here comes from caster correction. It makes a significant difference.
Old Sep 17, 2012 | 08:14 AM
Kojack's Avatar
Dynatrac,
it makes all the difference...differnce is here is that its a cheap way to fix it...
btw...if you want to beef up my Jeep as a favor im down for that! ha ha!
Do you make diff covers for my front and rear?
Old Sep 17, 2012 | 08:29 AM
Dynatrac's Avatar
Yes, we make diff covers for both the D30 and 44 (among other sizes).
D44 is DA44-1X4033-BB
D30 is DA30-1X4033-B
Old Sep 17, 2012 | 09:48 AM
Kojack's Avatar
Just found My diff covers...thanks! gotta find a dealer semi close by!
Old Oct 6, 2012 | 02:00 PM
LidLess07X's Avatar
Well.......After such a big improvement on my ride quality, I decided to go a little further. I talked with the guys at Northridge 4X4 and they recommended the EVO drag link flip kit. I tried it and yes it made another stride in improving my ride and on-road manners. Relatively simple install too.
Next is either the EVO plush ride coils or Bilstein 5100s. I'm not gonna do both together even though I know it would save some labor because I want to know exactly what improves and what doesn't. I currently have BDS three inch springs and their shocks that came with the lift kit.
What are your thoughts ?? Springs or shocks first for biggest ride quality improvement ???
