Drifting in 35's....
You may even find it straighten out a bit whenever you rotate your tires later on.
First thing I noticed when I went to 35s'. Luckily, I put the 4" lift on first and had alignment/caster checked
. Had no "drifting"
problem till the 35 mts' went on. It is minor but believe as others do, taller side walls, wider tire. As you said, its not bad, but its not stock either
