Driveshaft question
Ok... So generally the lowers are set to 23" to 231/8 to set wheel base and the uppers are used to raise the pinion or lower for caster.
I am assuming the lowers are at that (231/8") or close with the measurement you have.
I would still remove a arm or contact BDS. Check to see what they measure.
If the lowers are at 23" or so. Adjustable uppers will help get the pinion up.
