dumb flat towing question
Old Feb 24, 2007 | 07:02 AM
sdhexpert's Avatar
Default dumb flat towing question
Getting ready to put down some cash to order a JK. Would like to get an auto trans. Will be flat towing behind a motorhome. I'm assuming tranfercase to neutral and I should be good to go.
Anybody have any suggestions on a bumper / towbar combo that is available?
In <Thanks> Advance ...... for your comments
Old Feb 24, 2007 | 07:57 AM
wayoflife's Avatar
JK-Forum Founder
Hey sdhexpert, welcome to JK-Forum, it's good to have ya here!!
Regarding your question, if flat towing is all you need to do, you can always skip getting a new front bumper and just get a tow bar like thi...
Click here to see more pics
This is being made by Currie Enterprises, works with the factory front bumper and should be available soon if not already
Old Feb 24, 2007 | 08:01 AM
nmjk's Avatar
There are a few threads that cover this pretty well. Search around.
Quik answer is yes, auto will tow flat with transfer case in nuetral and steering wheel released. Check owners manual for exact procedures once you get it.
I am using the Blue Ox baseplate because I already had a Blue Ox tow bar. At least I can tell you that they are shiping and look pretty good. I was scared at first because of some of the pictures posted here, but it came out nice. There is only about a half inch between the bumper and the tabs that stick out, can't get much closer than that.
Good luck.
Old Feb 24, 2007 | 03:39 PM
Plugjug's Avatar
I have the same plan for flat towing my ordered Rubi. I called Pure Jeep Products and spoke to a tech. He said that the shackle mounts for the D rings on their front bumper were the best place to mount a tow bar. A little fabrication was needed for a new baseplate to marry the tow bar to the shackle mount location. Perhaps a two tab bracket to run a thru bolt to attach the tow bar. On the Warn bumper a tow bar was not recommended but they also have the D ring shackle mounts. I checked with my Jeep parts department for a Mopar tow bar but they couldn't find one in their catalog nor had seen one in ten years.
Old Feb 25, 2007 | 08:06 AM
CLACKEY(_!_)'s Avatar
Mopar has a factory tow bar as well. You can order from your dealer $400ish
Old Feb 25, 2007 | 08:11 AM
papabear's Avatar
Smile
And the Mopar Tow Bar fits the AEV Bumper. papabear
Old Mar 18, 2007 | 09:42 AM
dcmtfam
Guest
Posts: n/a
Anyone know why the manual says to unhook neg bat cable when flat towing?
