EGR valve replacement options?
Well, I went to most of the chain shops around town, thinking they would likely have the best tools to tackle this job, where none of them would install a customer supplied part and wanted to install the Dorman EGR valve which I wanted to avoid, and to install anything else besides the Dorman was going to be a special order, wait for the part to arrive. Quoted prices for labor and including the replacement Dorman EGR was around $300, which at this point I would be happy to pay if they didn't have to install the Dorman. I ended up dropping it off at a local mom and pop shop who would install my supplied part. I let the guy know I didn't do him any favors and rounded the bolt head off. He told me as long as it wasn't busted off, he could handle it......now I wait for him to call. Hopefully, he has much better luck than me and I haven't ruined his day with this job.
We'll see if there's a smile on his face when I go to pick it up.
Also I just realized I forgot to leave him my spline lug nut socket wrench to pull my wheel off. Typically, I leave it in my glove box but put it in my coat pocket to leave with the EGR valve and after this being my 4th visit to a shop, I forgot to pull it out and leave it. I guess I was too excited that he would do the work and install my supplied part. Hoping he has a spline lug nut socket, since I called an Uber to take me home and will need to catch another Uber to drop off the one in my pocket.
Well, I just received the call from the shop. They've had it for over 24 hours and couldn't get it off either. What an absolute sh*t show this is turning into.
Gonna try going to my usual shop who wanted to install the Dorman. My thought is if they can get to the point of actually installing the Dorman, swapping it out myself after the fact shouldn't be too difficult.
Hoping it isn't in any worse condition than when I brought it in. A broken bolt would be very unwelcome at this point.
Last ditch idea I have is getting in there with a pencil dremel with a cut-off wheel and start cutting that factory EGR off to provide some additional space to get on those bolts.
Just throwing out ideas, most of which are probably bad, hoping there's something helpful.
Edit: With enough careful grinding enough metal could be removed to break that flange in half, rotate each side separately, and loosen the bolts. Key words being "enough" and "careful" -- This is one tough job...
Originally Posted by bman
I have a standard 6 point combination wrench in 10 mm. You could take it, heat it up and bend it in the vise. I could get it to you whenever.
I hate using a phone to post. After I look at these posts I feel like my first grader has better grammar than I do.
