Sponsored by:
Sponsored by:
Electric Anti-Rust Gismo
Old 01-09-2007, 03:41 PM
Machster50's Avatar
Default Electric Anti-Rust Gismo
NEW INFORMATION PROVIDED AT PAGE 2 IN THIS POST... SEE INSTALL PICS...
HEy folks:
Given the harsh winter climate we have in this corner of the planet and the salt mines that are spread over our highways, I decided to invest in this product, available at Canadian Tire (in Canada, d-oh), or Crappy Tire as we affectionatley call them (but a really cool store by canadian standards anyway), and were on sale last week at $100 off, or $299 cdn, for the suv model gizmo .
It's called "CounterAct" and the product can be viewed at www.counteractrust.com
If anyone has tried this product, feel free to join the conversation, but as I see it, it's a dirt cheap investment if this works only half as good as they claim.
Essentially, the product uses 12V DC and converts it to high V, low amperage power that is sent via wires and 2 contacts, one in front, other in back (suv model) . The theory is that the current significantly prevents the oxidation process, ie oxygen contacting with iron. The pictures even show a significant reduction in rusting in areas like brake drums or rotors... places no amount of undercoating will ever / could ever be used.
Just looking to see if there is any experience out there with this product.
If there is interest, I will take pictures and post my attempt at the installation process...
Cheers!
Cheers!
ID:	553157   Click image for larger version
ID:	553158   Click image for larger version
ID:	553171   Click image for larger version
ID:	553176   Click image for larger version
ID:	553178   Click image for larger version
ID:	553180   Click image for larger version
ID:	553181   Click image for larger version
ID:	553183   Click image for larger version
Old 01-09-2007, 06:42 PM
Dean's Avatar
Iron oxidation is a constant, ongoing process. I don't think the transient application of a current does anything to slow the process. Sounds like a gimmick. I'm no chemist/physicist, but I took tons of chemistry classes and labs in my undergrad and this doesn't sound right to me.
Does anyone else know objectively?
Old 01-10-2007, 04:41 AM
PBR_Stitch's Avatar
Military ships use a (very vaguely) similar system to reduce the rusting on their hulls. That system does actually work, but it is a major energy hog.
Ron
ID:	562737   Click image for larger version
ID:	562738   Click image for larger version
ID:	562739   Click image for larger version
ID:	562740   Click image for larger version
ID:	562742   Click image for larger version
ID:	562743   Click image for larger version
ID:	562744   Click image for larger version
ID:	562745   Click image for larger version
ID:	562747   Click image for larger version
ID:	562748   Click image for larger version
ID:	562750   Click image for larger version
ID:	562751   Click image for larger version
ID:	562753   Click image for larger version
ID:	562767   Click image for larger version
ID:	562768   Click image for larger version
ID:	562769   Click image for larger version
Old 01-10-2007, 05:01 AM
chris269's Avatar
I work for a pipeline company and we induce a current on our pipeline to prevent corrosion. We have sacrificial anode beds that deteriate over time just like a battery deteriates. So instead of our pipeline coroding and going back to iron ore our sacrificial anode beds do. It's hard to explain the system intirely but i don't quite understand how something that is not grounded to the earth (4 rubber tires) could do this. I understand a ship doing because it is grounded through all of that water. I couldn't give you a 100% answer but it sounds fishy to me.
ID:	563019   Click image for larger version
ID:	563020   Click image for larger version
ID:	563021   Click image for larger version
ID:	563022   Click image for larger version
Old 01-10-2007, 05:20 AM
Egmont's Avatar
Originally Posted by chris269
I
<<<snip>>> I understand a ship doing because it is grounded through all of that water. I couldn't give you a 100% answer but it sounds fishy to me.
Ships are more my line and I also can't understand on how it works on a truck. On ships/boats it is actually called a cathode protection system. What it does is that it protects the hull and fittings from galvanic, eddy currents and so on by inducing an opposing electric current into the hull. This is accomplished by using battery voltage or going the passive way by connecting zinc anodes to the system, obviously it only works when submerged in salt water and has no effect in fresh water.
Old 01-10-2007, 05:49 AM
chris269's Avatar
If this really worked then auto manufacturers would probobly already be installing them.
Name:	Screen Shot 2014-07-11 at 10.01.49 PM.jpg
ID:	564934   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.03.27 PM.jpg
ID:	564935   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.03.58 PM.jpg
ID:	564936   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.04.37 PM.jpg
ID:	564937   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.05.05 PM.jpg
Name:	Screen Shot 2014-07-11 at 10.05.32 PM.jpg
ID:	564939   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.07.12 PM.jpg
ID:	564940   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.08.31 PM.jpg
ID:	564941   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.08.52 PM.jpg
ID:	564942   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.09.09 PM.jpg
Name:	Screen Shot 2014-07-11 at 10.09.34 PM.jpg
ID:	564944   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.10.14 PM.jpg
ID:	564945   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.10.42 PM.jpg
ID:	564946   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.10.58 PM.jpg
ID:	564947   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.12.17 PM.jpg
Name:	Screen Shot 2014-07-11 at 10.12.57 PM.jpg
ID:	564949   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.13.18 PM.jpg
ID:	564950   Click image for larger version
Name:	Screen Shot 2014-07-11 at 10.13.37 PM.jpg
Dean's Avatar
LOL!!
Sounds like I stand corrected. Won't be the last time!
ID:	564803   Click image for larger version
Old 01-10-2007, 06:15 AM
Archer's Avatar
"electrostatic corrosion control by capacitive coupling"
"minimizing corrosion"
"it runs off the 12V from the vehicle battery drawing less current than a typical digital clock."
Together these three components serve to induce a measured and specific negative electrostatic surface charge on the metal surface being protected (your vehicle's body for instance) thus capacitive coupling treats the metal body as if it were the negative half of a capacitor. This negative surface charge serves to interfere with the normal electrochemical corrosion processes that create corrosion on metals.
Went to the web site to do some reading. the above is what I found. doesn't seem to draw alot of power. I think the claim of "Rust Proofing" is a bit misleading. Everything I have ever been taught is corrosion starts the day the metal was made. however saying that it slows down the process would be safe. from what i read and know (no scientist however) it seems to use a negative charge to repel stuff from sticking to the vehicles thus if mud and water are slow to adhear then slow to rust. Or maybe I am just in my own reality and would appreciate a visit from ya'll every now and again
ID:	565847   Click image for larger version
ID:	565848   Click image for larger version
ID:	565849   Click image for larger version
ID:	565850   Click image for larger version
Name:	AZ Silver ditch.jpg
Old 01-10-2007, 11:30 AM
chris269's Avatar
Originally Posted by BeerMonkey
why do they care if the car rots out in 20 years. they already made $$ off you. and now your car is all rusty an dyou need to get another one from them.
When was the last time you got rid of a car because it rusted away. It would be a great selling point.
Old 01-11-2007, 06:32 PM
Machster50's Avatar
well, i'll install it this weekend and post a few pics - what the hell, for $250 bucks, I plan on keeping this one (jeep) for the long haul, hence the chance i'm taking. It might take me 5 years before I can tell if it works or not!
I trust this more than oiling or undercoating anyway...
Here's another site I found on the subject...
http://www.counteractcpr.com/CounterAct%20on%20TV.htm
ID:	608014   Click image for larger version
ID:	608015   Click image for larger version
ID:	608016   Click image for larger version
Quick Reply: Electric Anti-Rust Gismo
