ESP/ BAS came on won't turn off
Old Jun 23, 2009 | 10:40 AM
Piginajeep's Avatar
Originally Posted by tkob1060
could be one of the wheel sensors maybe? were you driving straight when it happened?
thats a thought, Did you unhook the esp lines and get some more length out of them?
maybe you pulled the wires out of the sensor
Bigshow's Avatar
I wheeled it mildly about a week ago but was just drving straight down the road. light came on as i was accelerating, did not do the pause like when i am on ice or slipping?
Old Jun 23, 2009 | 10:42 AM
Bigshow's Avatar
Originally Posted by ranwitscissorz
Have you checked the fuse or reset the ECU by pulling the battery cable?
I did not I will disconnect and try tonight
Bigshow's Avatar
Where are these located i did not disconnect on purpose maybe pulled out? or shook loose?
Old Jun 23, 2009 | 10:50 AM
ranwitscissorz's Avatar
There is one near each caliper, though when I swapped my axles, I forgot to plug in one and got 7 lights, not just esp/bas. They have a red lock clip on the electrical connector, just like your doors.
Old Jun 23, 2009 | 10:53 AM
Piginajeep's Avatar
well they wires are clipped to brakets, if you remove the wires from the brackets you can get about a foot of slack.
check for wires coming out of the backplates on the wheels
Old Jun 23, 2009 | 01:39 PM
JdTms11's Avatar
ive only got a mild 2.5 inch lift and i managed to rip a sensor out last time i went wheeling. thats probably what you did. i had the same problem afterwords accept mine actually locked the brakes up a bit by the time i got home i had no more rear pads and the rear rotors had to be replaced as well
Old Jun 25, 2009 | 10:20 AM
Bigshow's Avatar
all sensors where on and was getting frustrated, Out of dumb luck this light came on 2 days before I changed my driveshafts. changed the shafts and about 40 miles later the lights are off. BUT now i am noticing my wheel is not exactly centered. this will most likely make the light go back on right?
Old Jul 8, 2009 | 07:19 AM
beller's Avatar
Default ESP/BAS light stays on
I'm having same issue. Taking into dealer today. Had lifted, no issues. Took back into shop to have spare tire carrier and extend brake light. Watched techs at shop do work. He also wired trailer hitch light--did a lot of pulling of wires in rear end. Didn't notice lights on until a couple days after. Straightened steering wheel last nigth still lights on. Removed neg battery cable for 1.5hrs. Lights still on. We'll see what dealer says today and will post again.
Old Jul 8, 2009 | 01:02 PM
beller's Avatar
Dealer says steering clock spring bad. On back order--cannot locate part to replace. Who knows when will be fixed??
