Esp disable?
Old Apr 26, 2012 | 05:44 AM
  #21
jkrubcon's Avatar
Originally Posted by Jknockers
The following procedure will disable (or re-enable) ESP functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF. After performing the ESP disable procedure correctly,
“ESP OFF” will be displayed in the odometer for approximately 12 seconds each time the ignition is moved to ON.
Repeating the ESP disable procedure will re-enable normal ESP operation.
I tried this on my 12 Rubi a bunch of times and can't get the 12 sec confirmation you speak of.
Old Apr 26, 2012 | 05:53 AM
  #22
kh202's Avatar
Yeah has not worked on my 2012. Let me know it works for you!
Old Apr 26, 2012 | 06:27 AM
  #23
sstefick's Avatar
I'm a newbie here, and I was just curious why you would want to disable it completely?
Old Apr 26, 2012 | 06:39 AM
  #24
Dirty Dog's Avatar
Getting off the interstate into a ramp it would engage on me. Going up a hill it would come on. 2007's the steering wheel thing doesn't work.
Old Apr 26, 2012 | 06:41 AM
  #25
kh202's Avatar
Cuz it sucks. Won't let you freely spin tires to get thru mud and sand.. Also doesn't let you play and do donuts or powerslides in mud and snow
  #26
Dirty Dog's Avatar
Originally Posted by DanieltheManual
The fuse is linked with fuel pump?
Maybe in canada
Old Apr 26, 2012 | 08:21 AM
  #27
Chaseit1's Avatar
Default Esp
I have an '07 JK 2door 6spd manual and I was having the same problem on offramps . I don't know about the newer models but the ESP off button is only usable in 4WD not 2WD. To be able to disable and re-enable ESP you must take it to the dealer for 3 Flash downloads. After that it's a very simple procedure such as what has been described earlier. It works in 2WD as well as 4WD. Dealer charge $125.
Old Apr 26, 2012 | 09:16 AM
  #28
jkrubcon's Avatar
Originally Posted by kh202
Yeah has worked on my 2012. Let me know it works for you!
Is it a Rubi ?
Old Apr 26, 2012 | 09:23 AM
  #29
kh202's Avatar
Is it a Rubi ?
No sport s
Old Apr 26, 2012 | 05:10 PM
  #30
jereb83's Avatar
Originally Posted by Dirty Dog
No problems just lights on the dash. Come drive it for yourself.
I believe you...but slam the brakes real hard and see if the ABS kicks in. Lights on the dash indicates an issue. If it does not, then you know. Not that it matters. Isn't ABS optional still? Just a thought.
