Esp kicking in after drag link flip
I checked the wheel sensors and the appear to be fine. My only other thought is that with only a 3" lift that the flip is causing the drag link to be at too flat of a angle. Nothing is rubbing or binding but I know 3" is pretty shallow for the flip.
Centering the steering wheel is important of coarse.
Correcting the speedometer for actual vehicle speed is also important if you have oversize tires for several reasons.
When going straight down the road all 4 WSS signals should be equal, this is compared to the SAS(steering angle sensor) data which should be close to zero.
When turning the SAS angle sensed is compared to the differential wheel speeds through the SAS, the ESP program knows what the inside and outside WSS signals should be at a given steering angle.
If the data doesn't match a ESP code will be set. Common causes of this would be axles that are not centered which can cause crabbing. Wheelbase that is off left to right when running adjustable arms. Bent axle, a speedometer that is not calibrated correctly.......
These codes mainly set while turning at speed because that is where the difference is the greatest. I have even seen stock JK's in strong crosswinds throw ESP codes as you fight the crosswind with opposite steering input.
Not sure if this helps but something to check.
The drag link angle will not change how much the steering wheel rotates to effect a turn. Nor will the drag link angle change the difference of speed (rotation) of each wheel in the same turn at the same speed. The only change is how the force is applied to the pitman arm. Stock configuration with lift gives an upward and lateral force (from the knuckle). A flipped link has mostly lateral force and prevents unpleasant steering feedback particularly when striking a bump.
Ok I am running 33's but I corrected the speedometer. I will verify the steering wheel center when the procal arives. Is there a way to test the wheel sensors?
Well I got the procal today and steering wheel was perfectly centered so that's not the isssue. I double checked the tire size I had set previously with my superchip tuner and it is correct at 31.75 so I guess it is off to the stealership. Like I said before it the only thing that was changed was the drag link flip. I never had this issue previously.
