ESP Kill Switch Write-up
Just lifted my 2007 (RE 3.5) and put 35's on it. Love the new setup but don't like the "bucking/jumping" it does when I'm making tight turns on concrete. The ESP light illuminates on the dash and the vehicle "bucks" or "jumps" like crazy. If I push the ESP button it helps right then and there but it does re-enable itself somehow. I need a way to DISABLE ESP and if I have read all these comments correctly installing this switch will solve the problems I am having. What I am looking for is a yes or no as to whether or not this will solve my "bucking/jumping" problem from one of you who is more knowledgable than myself (wouldn't take much, lol).
Thanks all.
Thanks all.
Hi guys
I have the switch installed.....
Just some coments on the last few posts.
I believe there is a fuse that can be pulled.... If you just want to try before cutting wires etc.
One of my friends has a 'add a fuse' in this spot, with a series wired fuse and switch. A completely removable option. I didn't know of the fuse opption prior to installing my switch.
Wiring a lateral acceleration switch would work.... But you need to cycle the ignition to turn it on again. So after the first turn, it would be off for the rest of the drive.
Regards
Paul
Regards
Paul
Thanks all.
Thanks all.
OK, I did not read the thread all the way through, but my owner's manual has a way to disable it that works. Whole steering wheel-throttle dance.
Any reason this does not work for some? It worked for me.
Thanks for your help: mod in progress now.
Just FYI. According to the 2008 Owner's Manual:
The following procedure will disable (or re-enable) ESP functionality in the vehicle.
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left (counterclock- wise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESPOFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESP disable procedure correctly, “ESP OFF” will be displayed in the odometer for approxi- mately 12 seconds each time the ignition is moved to ON. Repeating the ESP disable procedure will re-enable nor-mal ESP operation.
Hope that helps.
Hope that helps.
Thanks all.
Thanks all.
