ESP turns on on high speed corners
I have a 07 with a 4" lift. I know most of all 07's do that. The computer needs to be flashed. A dealership can do that. Jeep was suppose to fix the problem in the 08's. I did alot of research on this. Some dealers will charge you though.
You don't unless you've changed your suspension dynamics. If that's the case take it to whoever installed your lift, they'll know what to do.
To the OP: If I'm in rain or light snow I reach over and turn it off to avoid the possibility of it kicking in when I don't want. If you've checked your components and nothing is amiss - you are going to fast.............. in a Jeep.
Thanks for all the replies. Just for the record, I am not going too fast, actually driving below the posted speed on turns. I believe it may be the steering centering or possibly an axle issue. I will read through the steering centering procedures, but how would I determine if the axle is off center?
sorry man, wasnt trying to be an ass, our thinking is different from computers
