ESP turns on on high speed corners
Old Nov 15, 2009 | 07:56 PM
  #21
captjay's Avatar
to determine axle offcenter, if im not mistaken: you should be able to tell by looking at your tires. if one side sticks out further than the other side, lets just say, the driver side was 3 inches from the edge of your fender flare and pass side was 2 inches past the edge of fender flare, the your axle would be off center. not very scientific, but thats how i i figurted out myu rear axle was not centered.
Old Nov 16, 2009 | 12:54 AM
  #22
spinlock's Avatar
Originally Posted by captjay
judt for the record, the computer doesnt care how fast the posted speed limit is. if the computer senses too fast or unstability, then it does what it was designed to do and thats to protect your brain. slow down dude
sorry man, wasnt trying to be an ass, our thinking is different from computers
This can occur very simply by giving the wheel a sudden input ( correction of sufficient magnitude) while in a constant radius turn.
What was the posted speed on the offramp curve where you doing 40 MPH?
Old Nov 16, 2009 | 03:00 AM
  #23
blockrockin's Avatar
it dosent always mean your going to fast at all .... sometimes when you have a lifted jk.. it just comes on at weird times..... i would just turn it off... i rather be in control and not have the computer putting the brakes on when i dont want them.. i think it causes more problems than help..
Old Nov 16, 2009 | 03:38 AM
  #24
Suffolk JK's Avatar
Highly doubt the computer is going to activate TCS in a BAD situation. It's there and senses when you're about to lose control, not when you actually want to drift around a corner? What I think anyways...
Old Nov 16, 2009 | 04:41 AM
  #25
phljeeper's Avatar
I have had some additional time to drive with this issue and have some updates:
I did re-center my axle - even though it was on 1/2 inch off, just wanted to make sure. It is still having this issue. I am absolutely not speeding, I have this issue around exit and entrance ramps that are posted 50mph when I am only going 40. It doesn't happen all the time, and seems to happen less now that I have re-centered. I am taking it to the dealer to reflash for the larger tire size to see if that helps. Please stop giving feedback to slow down (I am 35 years old and am over my speeding days). I am working through a legitimate issue that others here have had after adding larger tires and a lift.
Old Nov 16, 2009 | 05:15 AM
  #26
Yoda's Avatar
Originally Posted by blockrockin
if everything else is good, just disable the esp system : sometimes it acts weird when you lift your jeep . i like it better without it anyway
1. turn jeep on
2. set to 4hi
3. set parking brake
4. make sure steering wheel is centered
5. turn wheel to the right, 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, you may hear a chime at 5 seconds(and ESP OFF may show up on the speedo), but keep holding for 7 seconds!!!!
6. Turn wheel back to center then left 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, again, hold for 7 seconds!!!
7. turn back to center, and hold ESP for 7 seconds.
8. Turn Jeep off
Not a good idea The OP has a problem with the alignment, ESP of something like that. He has to find the problem, not masking it
Old Nov 16, 2009 | 05:50 AM
  #27
like I said before you have get the computer flashed. Look on project jk at the jeep esp
Old Nov 16, 2009 | 07:38 AM
  #28
hayward's Avatar
My wife has an 07, 2inch BB, 33's. ESP has come on turning right since i bought it. When I say truning right I mean off ramps and sweeping rights around 35 to 40 mph not just a normal right turn.
It has been to the dealer twice, still does it. Stearing wheel has been centered and rechecked. Stearing position sensor replaced. It is just something I live with now. If you find a solution tell the dealer, they will never figure it out on their own. And why only Right turns
Old Nov 16, 2009 | 08:14 AM
  #29
Yoda's Avatar
With a 2inch BB, 33's. IT'S REALLY NOT NORMAL
Old Nov 16, 2009 | 08:24 AM
  #30
hayward's Avatar
I know it isn't normal. I drive an 09 with 3.5" lift and 35's never had it come on once. It is just not as simple as centering the wheel or driving too fast.
