evo bolt on coilovers on 35's?
Old Oct 11, 2013 | 02:21 PM
JKJeepJunkie's Avatar
Not trying to jack the thread but can you run coil overs with short arms
[J][E][E][P]
Old Oct 11, 2013 | 02:23 PM
Jeek.OlllllllO's Avatar
[J][E][E][P]
I think you can but its about 1700 for the arms so might as well just do it right away!
Old Oct 11, 2013 | 02:34 PM
alanscott1's Avatar
Originally Posted by aaronstephen
What control arms are you running?
Sent from my iPhone
Rock Krawler Pro mid arms
Old Oct 11, 2013 | 02:39 PM
I got adjustable JKS arms will they work
[J][E][E][P]
Old Oct 11, 2013 | 04:49 PM
TheDirtman's Avatar
You can run factory arms with coil overs if you want. The amount of lift you put into it will dictate wether you need adjustable arms or not.
Old Oct 12, 2013 | 06:53 AM
Nwapache's Avatar
Learn from those who traveled the same path before you. Coilovers+short arms=tatered bushings. Mine last less than 6 months after I switched to coil overs. Definitely stick with your current plan and run long arms right out of the gate.
Old Oct 12, 2013 | 07:25 AM
Maertz's Avatar
then use rod ends? i see no need for long arms unless you go with a big lift or stretch it.
