EVO C Gussets and AEV
not very hard at all. wheel it hard enough and it will bend a lot. before we installed a set of gussets on our old dana 44 (no sleeves), we had as much as 2° of camber on our passenger side wheel and 1.5° on the driver side. after installing the gussets and running 37's and wheeling the piss out of our JK, we saw NO additional camber.
MONEY - doesn't make sense to sleeve them until I can regear too. I know, I know - "WHAT 37" on 4.10s - maddness!!"
"Buy Jeep parts or pay the rent
My signing bonus was quickly spent......."
So yea doing what is most cost effective and vehicle effective right now I think is on alot of guys minds and worth discussing. If more guys running larger tires input their camber measurement and we see a pattern that the passenger side has more negative camber then the drivers I think we could say the sleeve maybe more important then the gussets but sure both are a good idea.
I had the evo's installed before any mods were done. I'm currently running 37's and have not had issues with the C's bending.
I'm not concerned about the tubes. we beat the hell out of ours Jeeps in Moab and my front axle is fine...
i was playing catch up with Northridge4x4.... this was after his hemi build
I bottomed out very hard, and nothing was damaged.
Based on the different responses to this same question, I have come to the conclusion that I will install the aev lift and then have Offroad install the C Gussets; I suspect they have to modify the brackets slightly to accomodate the AEV brackets. I am afraid if I did things in the other order, the AEV bracket would no longer be a simple bolt on application.
Any one found a good replacement for the stock ball joints that are failing? I know Dynatrac is working on some but have not been released yet. Napa has some misalligned ball joints that are suppose to be stronger than stock but I do not have verification of this yet.
There is alot more tube on the passenger side. I now have EVO gussets and hope to see no additional camber but wonder if some bending of the tube will still happen?
that's what i'm saying. if i'm wrong, i'd like to know as much. i did and did not see a correlation.
