Fender Chopping!!!
Old Apr 5, 2013 | 08:26 AM
newjkman's Avatar
Default Fender Chopping!!!
I'm thinking of trimming my fenders. Do you do it on the jeep or take them off first? Does anyone regret cutting theirs and if so why?
Old Apr 5, 2013 | 08:55 AM
Rob 12B1P's Avatar
You do it on the Jeep. I Like the way they look cut no regrets for me. Pretty sure theres a write up on here somewhere if you search for it.
Rob
Old Apr 5, 2013 | 08:59 AM
BigSteve's Avatar
I cut them on the Jeep. I just ran a tape line on the fender where the fender starts to turn down and cut away. On the front I measured about 3 inches up from the front edge and cut across. Then just shaped it the way I want it. Then yanked the rear liners, modified the front liners and trimmed the front fender supports. Pretty easy, it's just time consuming.
Old Apr 5, 2013 | 09:32 AM
Irish Bullfrog's Avatar
I actually cut mine last night in anticipation of installing my 35's today. My 4" Lift goes on Tuesday but I had to make it all work logistically..
It does look funny with the stock tires on but if you are going bigger, it is the way to go.. I am sitting in Discount Tires waiting for my 35's to go on.. ;-)
Here is a link to an awesome video if you're going to do it... I also kept my rear fender well liners, but most just chunk them and paint the inside of the fender well... I can give you the details if you want to keep them, I think it looks better with them..
http://youtu.be/EppDwS34sXs Here are pics of mine last night...
Bullfrog
ID:	443194   Click image for larger version
ID:	443195   Click image for larger version
ID:	443196   Click image for larger version
ID:	443197   Click image for larger version
ID:	443199   Click image for larger version
Old Apr 5, 2013 | 09:35 AM
Insidejob01's Avatar
Do it and never look back it makes a huge difference!
Old Apr 5, 2013 | 09:48 AM
The Green Monster's Avatar
That is the main video I used when I did mine. I have no regrets with my fenders. My front liners, however, don't look like I want them to, but they are acceptable.
These were taken before I sprayed the fender wells flat black. They look much better after the paint.
Old Apr 5, 2013 | 10:04 AM
SebasCbass's Avatar
Jeep looks great! You did an awesome job cutting the fenders
Old Apr 5, 2013 | 10:07 AM
SebasCbass's Avatar
The hardest part about doing this is making the first cut. Once you do that, there is no turning back and you will make them look great no matter what. Careful trimming the inner fenders on the front. I cut mine too much and there is a big gap. You can just remove the inner fenders in the back since they aren't needed.
Good luck! You will do fine.
Old Apr 5, 2013 | 11:19 AM
jrylb73's Avatar
I did mine last year and don't regret it at all.
ID:	443230   Click image for larger version
ID:	443231   Click image for larger version
ID:	443232   Click image for larger version
Old Apr 5, 2013 | 11:29 AM
Looks great!!
Bullfrog
