fog light bulb
Old Dec 27, 2013 | 01:31 PM
jlfuksa's Avatar
Default fog light bulb
Whats the brightest replacement bulb for stock fogs
Old Dec 28, 2013 | 05:20 PM
Bonedoc's Avatar
I think the sylvania Silverstar is. I have them and I get flashed regularly because of how bright they are. They are pricey, 35-40 for a pair but work well.
Old Dec 28, 2013 | 05:49 PM
Jersey_Devil's Avatar
EBay.... Search led replacement bulbs u can even search SMD bulbs. $30 per pair I got amber and 6k to match my tl's
Here is a link to the amber ones, the seller also has the 6k cool blue ones too
Check out this item I found on eBay:
End time: Jan 19, 2014 12:20:55 AM
Item: 2 x H16 Yellow LED Bulbs DRL Fog Lights Lamp SMD
URL: http://pages.ebay.com/motors/link/?n...d=271006845159
Alt URL: http://www.ebay.com/itm/2-x-H16-Yell...-/271006845159
(Sent from eBay Mobile for Android)
Sent from my obama monitoring device
Old Dec 28, 2013 | 09:09 PM
karls's Avatar
LED bulbs will not be the actual brightest for viewing the road even though they may appear brighter in the housing. Simple searches will reveal that. I would stick with the factory bulb (since you're limited to 24w on the stock fogs) or go to the LED cubes from any manufacturer- they will be brighter.
Old Dec 29, 2013 | 05:13 AM
These bulbs are MUCH brighter than the stock lights. No doubt in my mind they are brighter. The stock fogs suck as bad as the headlights lol
Old Dec 29, 2013 | 05:38 AM
TJJK's Avatar
Fog lights should be chosen for beam pattern (wide and flat) not brightness (lumens and lux). Best advice would be to eliminate the plastic cover and go with a LED replacement with a lead crystal cover or polycarbonate. White light would be my first choice followed by Amber.
Old Dec 29, 2013 | 08:46 AM
KevinMac's Avatar
Alt URL: 2 x H16 Yellow LED Bulbs DRL Fog Lights Lamp SMD | eBay
Those are interesting. I tried other bulbs from eBay and ended up pulling them out yesterday. I had these in for a bit over a month and both broke...plus the light output kind of sucked.
Old Dec 29, 2013 | 08:47 AM
courtsm3's Avatar
Just went with a Hella H16 replacement on my 11'. Stock replacements were $30 each!! Got the pair of hella's for $32. Slightly brighter and whiter. I believe they're 35W.
Old Dec 29, 2013 | 12:30 PM
CbtEngr's Avatar
I've had these for a while now. Just need to slice off one tab as it seems to be on the wrong side. No other modifications needed. Pics in my profile.
Amazon.com: Nokya Hyper Yellow H16 9009 5202 Foglight Bulbs: Automotive
Name:	Nokya Foglight Bulbs.jpg
Old Dec 29, 2013 | 01:18 PM
Here's what mine look like
