Front differential problem
Old Feb 3, 2011 | 12:43 AM
Black rose's Avatar
Default Front differential problem
I just installed the 4.88 ring and pinion and while braking i heard a grinding noise from the front diff and the car was shaking...then i tried to drive and it only moved a little and it stoped again.
Really hope it not the ring or pinion.
Old Feb 3, 2011 | 01:33 AM
nthinuf's Avatar
Could be the brakes were not put back on correctly, but more than likely, it is the gears. Don't try to drive it anymore, have a flatbed tow it back to the shop.
Old Feb 3, 2011 | 05:45 AM
wayoflife's Avatar
JK-Forum Founder
oh man, not good. until you know for sure what's going on, i would have to say that you should have your jeep towed back to your shop and have it looked at.
Old Feb 3, 2011 | 08:44 AM
Black rose's Avatar
as soon as the problem occured i stoped the car and called the shop and called recovery...had it towed to the shop again.
