Full Traction 2" BB Install Tricks or Tips
Old Dec 28, 2006 | 11:18 AM
crazy4sip's Avatar
Default Full Traction 2" BB Install Tricks or Tips
I finally made up my mind and ordered the Full Traction 2" BB lift.
To those of you that have installed this lift, is there anything I should be prepared to alter or fabricate in addition to what's provided ?
I saw a post from someone on the board that mentioned having to make a improv bracket for the brake lines because they wouldn't reach.
Any other info would be appreciated.
As always thanks in advance, and I hope the New Year brings many newly delivered JK's to those who are waiting.
--Bill
Old Dec 28, 2006 | 11:31 AM
2K1TJ's Avatar
I'd drive it before installing the trac bar bracket. You may not need it. I mentioned having a bit of bump-steer after the install and someone said to try removing the bracket. I haven't yet though.
As for the brake lines, I didn't do any mods to them, but I loosened the bracket that holds the rear ones to the frame so I wouldn't over-extend and break them during the install. I secured them when I was finished though. I also did this to the e-brake cables. All this may have been unnecessary, but I wanted to be sure. Also, the rear diff breather tube popped off so I had to put it back on. It's just a push-on fit. There wasn't even a clamp there. I guess I should add one.
Old Dec 28, 2006 | 01:46 PM
crazy4sip's Avatar
Thanks for the info, sounds likea good idea to lossen the brackets better safe than sorry. I'll try the install without the bracket I can always add it later If needed.
BTW how do you like the Maxis Bighorns ? Their also on my list along with the Cragar Soft 8's
Thanks for the Input
--Bill
Old Dec 28, 2006 | 02:14 PM
J33P JK's Avatar
I would suggest to leave the track bar relocation bracket off. Also if you plan on running disconnects and putting longer shocks on it then I would say that the rear brake lines will be too short. I had to make a bracket to extend mine. There really isn't much line there. The front "should" be OK, but at full flex mine are a little tight so I'll be getting extended brake lines before too much longer.
