Full Traction adjustable arms rusting?!?!?
714-870-5515
EVO1016: EVO ClampNut
Patent Pending
This part threads directly onto 1-1/4 heim joint/johnny joint, replacing the supplied jam nut. This nut clamps onto the thread of the joint to help prevent loosening aswell as has an O-Ring (in green in the photo) which seals the inside of the control arm tubing from water and debris.
This is why we make this...
man, I didn't think about the part inside the arms. I did use a good amount of antisieze when I assembled, so it should be ok in there. I will wire bush them clean then reapply the antiseize
