Full Traction adjustable arms rusting?!?!?
Old Jul 15, 2008 | 09:52 AM
Piginajeep's Avatar
Originally Posted by CarFanatic
ya thats whats rusting on mine. the threads
if its the threads just cover that shit in anti-sieze... It'll protect it from the weather. I'd like know what Jeep paints the frame and axles with it doesnt hold up for anything
Old Jul 15, 2008 | 12:56 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
I think its either black crayon or crayola markers
Old Jul 15, 2008 | 02:58 PM
Patrick @ Full Traction's Avatar
The threads should be wire brushed clean. After that lube it with a good amount of Anti-Seize. You should not have a problem after that.
Old Jul 15, 2008 | 04:12 PM
Evolution's Avatar
Sponsoring Vendor
so I happen to notice that the treads on my Full traction Lift are rusting already! My jeep has 1800 miles on it! IS this normal?? you would think they would have used SS or something with a rust coating??
Give us a call, we have a fix for this. This is a common issue for joints with a jam nut from any manufacturer.
714-870-5515
EVO1016: EVO ClampNut
Patent Pending
This part threads directly onto 1-1/4 heim joint/johnny joint, replacing the supplied jam nut. This nut clamps onto the thread of the joint to help prevent loosening aswell as has an O-Ring (in green in the photo) which seals the inside of the control arm tubing from water and debris.
This is why we make this...
Old Jul 16, 2008 | 05:26 AM
CarFanatic's Avatar
man, I didn't think about the part inside the arms. I did use a good amount of antisieze when I assembled, so it should be ok in there. I will wire bush them clean then reapply the antiseize
Old Jul 16, 2008 | 06:21 AM
I think that will work best for you. Let me know how it turns out.
Old Jul 16, 2008 | 06:29 AM
CarFanatic's Avatar
will do!
