Gear install problem
I had 5.13 installed in my Jeep and picked it up late Friday afternoon. This morning I go out to the garage and notice my front diff is bleeding.
I inspect and it appears to be leaking from 2-3 bolts. How do I fix this? Out some seal on just the bolts or do I have to redo the whole seal?
By the way I love the gears.
Thanks!
I inspect and it appears to be leaking from 2-3 bolts. How do I fix this? Out some seal on just the bolts or do I have to redo the whole seal?By the way I love the gears.
Thanks!
is it leaking around the bolts at the diff cover? if so it is a easy fix. drain dif and clean cover off and housing and resilicone.....if coming from axle tubes then it is a seal issue and take back to shop for them to check....
https://www.jk-forum.com/forums/show...+cover+install
or you can go this route, and use lubeloc gaskets...
Do you mind telling us how much it cost to have the gears done? I'm curious because a lot of people are getting their gearing done. I've been given quotes of 14 hours labor. At that preice i should just buy new axels
They make things so much simpler and work like a charm.
That's a rip off!!!
