Gear Ratio on 6.0 (L96)
Old 06-26-2019, 10:48 AM
misplacetexan's Avatar
Default Gear Ratio on 6.0 (L96)
Have saved enough pennies to replace my 3.8 (with 198K miles) with a L96 (6.0) engine. Just wondering what gears folks are running with their converted JK? My current tire size is approximately 34". My Jeep is my daily driver. I currently have 4.88, which work great with the 3.8, but I am pretty sure those gears are a little too low for the L96. Thanks for your assistance and knowledge in advance.
Old 06-26-2019, 12:36 PM
4wheels4life's Avatar
I am running 4.10's with my 35's. 2100 rpms at 80 mph. 1600 rpms at 60 mph, Daily driver.
misplacetexan (06-26-2019)
Old 06-28-2019, 12:48 PM
MTNBKR's Avatar
I have the 6.0 and L96!in my 08. Run 5:13's on 37s and is my daily driver. If you do more daily driving than anything else then go 4:56. Perfect gear for both worlds thru 38's. Give either MOTECH or RPM Extreme a call to educate yourself further. Good luck and enjoy your swap
misplacetexan (06-28-2019)
Old 06-28-2019, 03:32 PM
Have received an estimate from MoTech and just have to make logistic planning in dropping off the Jeep in Las Vegas. Have to make sure I have vacation plans for dropping off and picking up Jeep.
Old 06-29-2019, 06:18 AM
caryt's Avatar
My JK is heavy, 6500lbs before loaded with camping gear.
5.38's and 40's, 2100 at 70mph+- and I wouldn't suggest any other gearing.
Robbie will say 4.10's but thats great for a light JK not onebuilt up and loaded for trails.
Just a FYI I'm making little over 400 HP-TQ at the crank.
I would talk to John @Overland Performance first before going to Robbie.
Also EXODUS JEEPS is in Texas.
https://exodusjeeps.com/jeep-ls-engine-swap
https://overlandperformance.com/
misplacetexan (06-29-2019)
Old 07-01-2019, 05:11 PM
iloozealot's Avatar
I'm sorry to ask but what does a swap like this cost? I have a number in mind, I would say 5k for a swap kit, 7k for a plug and play, and maybe another 5k labor?
Old 07-02-2019, 11:40 AM
Riptide9's Avatar
I have a 2011 with the L96 swap and am running 4.88 gears on 40's and my Jeep weighs 6400lbs. It idles down the highway at around 1850 rpm and is perfect IMO
misplacetexan (07-02-2019)
Old 07-02-2019, 04:11 PM
un lupis's Avatar
^^^^agree^^^^
My 2dr is @ 5200lbs and I'm on 37's and tons , LS-3-6L80E and run 4.30 gears , John do know his shit for sure . Weight and how your rig is configured makes a big difference in selection of ratios .
What is more important is how you will use your Jeep , the way I use mine will differ from the way you or anyone else uses theirs .
Old 07-02-2019, 06:08 PM
The L96 (6.0) installed starts around $15,999 and goes up depending what other goodies you want to add. I am adding a duel row radiator, Camaro SS fan, 2012 tap shift, re-gearing, and a few other things. So, I will be paying over $22K.
Old 07-03-2019, 01:32 PM
iloozealot's Avatar
Thank you. It's good to know I wasn't far off. I think between doing the engine/trans swap and axle swap, suspension, wheels/tires. I can see why people have 75k into one of these including purchase price. If you have the "best" of everything I could see an easy 100k if you had it all done.
misplacetexan (07-04-2019)
Quick Reply: Gear Ratio on 6.0 (L96)
