Gears
Old May 30, 2013 | 11:41 AM
Travdd's Avatar
Default Gears
I have a 2007 jk about to run 5:13 gears. Can you run 37inch tires with those gears?
Old May 30, 2013 | 11:43 AM
Riznoy's Avatar
5:13 is the proper ratio for 37s
Old May 30, 2013 | 12:11 PM
Travdd's Avatar
I have a rubicon express 2.5 lift with a 1 inch teraflex front spacer. I'm running 35 but want 37 can I do that with my lift or do I have to lift it more?
Old May 30, 2013 | 12:44 PM
Riznoy's Avatar
Theoretically with flat fenders u can run 37s with no lift. Realistically if u plan on wheeling and getting good flex you should have a 4" suspension lift. You should be fine with your lift if u have flatties, u might have to do a little trimming on the pinch seem.
Old May 30, 2013 | 07:07 PM
DesolationMania's Avatar
Yes, you'll be okay, but you could go 5.38 as well.
Name:	JK Gears.jpg
Old May 30, 2013 | 07:35 PM
nthinuf's Avatar
More information would get you better answers. 2dr or 4dr, auto or manual, mostly in town or mostly high speed freeway, towing, axles (D30/D35/D44), added weight/armor, stock flares or flats, disconnecting, fire roads or flexing in the rocks, whatever else may be relavent.
If you haven't found the FAQ's yet, you might give them a quick read. (stickied right at the top of this modified area.)
