Going with 35's - Heard I need C Gussets??
Old May 2, 2012 | 11:31 AM
NativeMsSon's Avatar
It is true. The end forgings on the JK front axles or, "C's" are really weak and will bend with anything other than stock wheels/tires. Running 35's even around town will eventually cause the C's to bend and that will give you camber that cannot be corrected or, at least, very easily. C gussetts will help prevent this from happening.
Hey WOL. Not to hyjack, is this true for the D44 front also? I am planning on going to 33's soon. Thanks
Old May 2, 2012 | 11:34 AM
wayoflife's Avatar
JK-Forum Founder
unfortunately, yes. the JK rubicon 44 is for the most part, a dana 30 with a 44 differential and axle shafts.
Old May 2, 2012 | 11:40 AM
IN the BLACK's Avatar
If you have the Dana 30 in front, it will bend going to the grocery store with 35's. If its a Dana 44 your good for light wheeling as is. Hope that helps....
Originally Posted by Bunk
I have a 2012 auto with 3.73 gears. I am planning to go with 35" tires on a 2.5 AEV lift.
I heard that I need C Gussets if I do this.
Can anyone tell me if this is true and why?
FYI- I don't plan to wheel this thing a ton. Perhaps 2-3 times a year.
Thanks!
Old May 2, 2012 | 11:42 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by IN the BLACK
If you have the Dana 35 in front, it will bend going to the grocery store with 35's. If its a Dana 44 your good for light wheeling as is. Hope that helps....
actually, there is no dana 35 front, only dana 30 and the dana 44 has the exact same c's and even tubes as a dana 30. it will bend just the same.
Old May 2, 2012 | 11:48 AM
Noxian's Avatar
the Dana 30 and 44 have the same ends and tubes, both are just as likely to bend.
Old May 2, 2012 | 12:02 PM
LMT Rubi's Avatar
how long would you say I have before bending can occour? I got my 35s about 2 months ago and have not done the C gusset mod yet. I have not done any off roading either.
Old May 2, 2012 | 12:03 PM
loanwolf2005's Avatar
Default D30
no problems yet 35's and D30....although they only measure about 33.75 (BFG MT's)I think many more folks run them without anything especially if it's mostly a daily driver.
you'll definitely want the AEV Procal too.......shifts alot better(smoother) and turns off the TPMS light too
Old May 2, 2012 | 12:04 PM
Thanks for the replys. Looks like gussets are in my near future also.
Old May 2, 2012 | 12:05 PM
mandor6863's Avatar
I have been thinking of this insurance. I drive mine as a daily driver but when hitting some pavement seams with the 35's, I could see it as being a decent amount of stress.
I have welding experience and have wondered is the process of welding the gussets on does not introduce some of it's own weaknesses.
Anyone have input/experience?
Mandor6863
Old May 2, 2012 | 12:10 PM
MTG's Avatar
MTG
Well, I do have a welder...looks like a have a weekend project! Thanks for your help and advice.
I considered it cheap insurance and I had to pay someone to weld them for me. Sounds like you are good to go.
