got a winch! now do I need a battery?
Old May 12, 2013 | 05:27 AM
winkelhawk's Avatar
Ditto on the Optima, always had good luck with them. Waiting for my stock battery to take a dump to by a yellow top. I have heard the Odyssey is a great battery also.
Old May 12, 2013 | 05:28 AM
Smashboogie 4x4's Avatar
Former Vendor
The winch will definitely put extra stress on the battery however the factory battery is good enough until you need to replace it. We have our winch, OBA, lights, CB, and numerous other changing devices running off the factory battery and still no problems. When we are using the all of those components we keep the engine running and when the winch is really working hard we bring the RPM up a bit to help the battery and prevent overloading the charging system while sitting there at idle.
Both the Optima and Odyssey batteries are good high quality batteries and will assist with the added electrical accessories we all rely on. One of the nicest features of these batteries is that they are both Dry Cell batteries, as opposed to the typical lead acid battery. Over working a lead acid battery will result in battery acid boiling out the top and spilling which makes a mess and causes rust and corrosion issues. The down side to the dry cell battery is that if you let it completely die it is more difficult to bring back to life, but it you keep them charged all the time they last and perform well for the life of the battery.
Old May 12, 2013 | 05:33 AM
familytime's Avatar
JK Forum Regional Rep
Originally Posted by Ryan0260
My Optima yellowtop has been great.
x2,been running our red top since 2007.Unless your doing alot of winching,you don't need a deep cycle.These type of battiers require you to cycle it down to near dead to make them last
Old May 12, 2013 | 06:59 AM
SBEII's Avatar
Originally Posted by Jhouse93
Thanks for the opinions guys, have heard good things about sears diehard. To be honest my winch womt be seeing that much action so ill probably just use my current battery up before upgrading
That's what you should do. Unless you're doing a lot of long pulls, you'll be fine. I'm running the stock battery and haven't had any problems.
Old May 12, 2013 | 01:30 PM
Ryan0260's Avatar
Mine is a deep cycle.
Old May 15, 2013 | 10:46 AM
Jhouse93's Avatar
Thanks for chiming in guys, I know you all work your winch hard...I was there at raucsh creek helping spot you out of that rock garden
Old May 15, 2013 | 11:33 AM
thegoat's Avatar
On the stock battery after two good pulls, starting on the 3rd the battery light came on, I was using the throttle also so the engine was revving. I suggest getting a dual battery setup & possibly a high output alternator if you are going to be using the winch much.
Old May 15, 2013 | 12:53 PM
Ryan0260's Avatar
A single deep cycle battery and the factory alternator, as long as it is working properly are normally sufficient...
Old May 15, 2013 | 01:16 PM
thegoat's Avatar
Good to know, thanks for the information!
Old May 15, 2013 | 02:50 PM
Former Vendor
We remember that clearly!!
If the battery is old then yes you will have trouble but only two or three years won't be an issue.
We gotta wheel together again!
