Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
On the stock battery after two good pulls, starting on the 3rd the battery light came on, I was using the throttle also so the engine was revving. I suggest getting a dual battery setup & possibly a high output alternator if you are going to be using the winch much.
Dual battery is definitely a nice to have but isn't absolutely needed until you really over load the alternator by running lots of electronics at the same time.
One of the nicest perks of a dual battery set up is that you can always jump start yourself!
At what point is it a good idea to go to a high output alternator?
If the battery is old then yes you will have trouble but only two or three years won't be an issue.
We gotta wheel together again!
We do ot was a good timeare you all going to be at OC jeep week?. Just a update. Got the winch all hooked up and it works great. Even pulled a friends 1500 ram in park about 20'.
