guys with RIPP SC, i need help
Old Jan 9, 2011 | 04:58 AM
  #31
RIPPMODS's Avatar
Sponsoring Manufacturer
bump
Good?
Old Jan 9, 2011 | 06:19 AM
  #32
btomike's Avatar
Originally Posted by RIPPMODS
bump
Good?
Well i have to adjust it with more threads showing. It maybe has 3-4 and its better but it seemed to have more power by cranking it down a little more. Too bad it was surging. I havent looked for a vacuum leak yet bit Im sure the hoses i messes with are tight. Dont get me wrong though, Im still loving this thing.
Mike
Old Jan 9, 2011 | 04:56 PM
  #33
RIPPMODS's Avatar
Mike
Your supposed to be making the valve tighter - did you adjust the throttle response?
TECH
Old Jan 9, 2011 | 05:41 PM
  #34
btomike's Avatar
TECH
Yes i fixed the throttle
Old Jan 12, 2011 | 10:43 AM
  #35
RIPPMODS's Avatar
So how are we doing now...
RIPPTECH
Old Jan 22, 2011 | 05:21 PM
  #36
seabass's Avatar
I found this thread very helpful and wanted to add.
Just did the install myself. I went surprising well, I would rate it less difficult then installing a lift kit and way less rusty bolts to deal with.
My tips would be.
  • Spray all bolts you are removing with a loosener the night before.
  • A good set of cutting plyiers are very handy,
  • a Upholstery Clip Removal Toolis very handy for all the push in plastic holders, h t t p://w w w.amazon.com/Tool-Aid-87810-Upholstery-Removal/dp/B000IHK1N6
  • You will need at least a foot long extention and swivle. Deep and standard sockets were used.
  • Gas shoots out when you pull out the first injector, so just be ready for that.
  • Cut the main vacuum line when you pull the plenum, it needs to be revomed anyways.
  • Access the far back spark plug the same way you get and the bottom of the EGR tube, through the passenger fender well, it makes it very easy.
  • I bought a hat with lights in it a while ago, invaluable for working in the evening and looking in tight places. h t t p://toronto.flyerland.ca/products/marks-work-wearhouse-windriver-led-ball-cap-product-6108686
  • And lastly I shaw that picture of Jack from avenger standing in the engine bay while working. That worked great, there is actually enough room to stand on the axle, however once the sc is in, that comfortable spot is gone.
I am running the standard 2.2 tune and it worked great right from the start. The Jeep really goes now, I can't believe (and thankful after spending $$$$$) how smooth the power is, seems to add through the entire rpm range. No codes or drama. I am pleased with the sc so far. Start to finish was about 12 hours, but at least 3 hours was dealing with taking the winch and bumper off and on. I modded the grill so it comes out now with the winch on.
I am working with ripp to to tweek things a bit, but no major complaints.
Last edited by 07rubisteve; Jan 22, 2011 at 07:41 PM. Reason: Please no direct links to non sponsors
Old Jan 22, 2011 | 07:37 PM
  #37
RIPPMODS's Avatar
My tips would be.
  • a Upholstery Clip Removal Toolis very handy for all the push in plastic holders, h t t p://www.amazon.com/Tool-Aid-87810-Upholstery-Removal/dp/B000IHK1N6
Great input thanks for that - So cool you got it all done in one day - glad to hear it went smooth. Should you need any dial in assistance please use the tech@rippmods.com and we'll be glad to help.
TECH
Old Jan 25, 2011 | 07:17 PM
  #38
seabass's Avatar
Maybe you can give tech@rippmods.com a poke for me. A couple questions from weekend they haven't got back to me on yet.
thx.
Old Feb 26, 2011 | 10:20 PM
  #39
Dan415's Avatar
Default SC
Hey,
So do you guys suggest I get new headers at the same time and do them as one install. I have the Gibson dual, and read a few reviews about new headers really helping the RIPP SC.
Did you guys change out your headers?
-Dan
