guys with RIPP SC, i need help
Old Dec 29, 2010 | 08:48 PM
  #21
Rottwheeler's Avatar
YingYang: Are you happy with the performance you gained? What made you choose the SC vs. a Hemi? Thanks!
Old Dec 30, 2010 | 05:18 AM
  #22
YingYang's Avatar
Oh yea, im really happy with it. Your not gonna set a land speed record but thats not the point behind it. Its just a different Jeep now. I love driving it even more. I use to struggle on the interstate at 65mph in my brick. Now 65 sheesshhh, 75 is where this thing wants to be. Dont expect a Hemi but for me.....
SC or Hemi. I think 99% of the people would agree, if you got the $$$$ get the Hemi. I just didnt have the $$$$. SC was my best option and what a great option it is.
Old Dec 30, 2010 | 05:26 AM
  #23
YingYang's Avatar
Originally Posted by RIPPMODS
Add:
  • When tighteing the spark plugs watch the angel of the socket, some have cracked their plugs and their not easy to find local.
  • Before re-installing the spark plug wires makes sure the wires didn't come appart internally when you pulled them off. This is a great place for a misfire to randomly appear.
  • When re-installing the EGR tube, make sure the integrity of the EGR gasket on the cylinder head is sound. This is a great place for a vacuum leak to hide.
  • Make sure you don't press any of the injector grommets out - doing this right the first time saves you the hassel of the second time. We spent a lot of time detailing any obsticles refrenced above.
Looks like I need to learn how to use the list feature.
Great additions.
I always start my plugs by hand, or well with the socket and extention in my hand. I was able to find the plugs at my local O-o-o O'Reillys. I couldnt believe it. They were a little under $2 ea. A+++
Old Dec 30, 2010 | 10:57 AM
  #24
RIPPMODS's Avatar
Sponsoring Manufacturer
Great additions.
Nice - great job on the spark plugs - with the GEN1 we provided iridium spark plugs because they were harder to get to. they were $12-$15 each - with the GEN2 we stepped down to a copper core V series NGK (great reliable plug) you can read them once a year and replace as per inspection.
TECH
Old Dec 30, 2010 | 01:28 PM
  #25
btomike's Avatar
got a big question..
does the egr valve go all the way in the tube? if not, how does is connect to the engine?? thanks..
Old Dec 30, 2010 | 02:40 PM
  #26
YingYang's Avatar
LOL, that damn thing, I remember that. Lub it up, get a deep well socket and push it as far as it will go. It will almost make it to the 90 deg bend. Just get it far enough to be able to put on the clamp.
EDIT: Make sure its facing the right direction!!!
Old Dec 31, 2010 | 12:54 PM
  #27
btomike's Avatar
Well i finally got it done. Had to take the sc of to put the damn filter thing on, forgot to do it, guess i was excited.
One suggestion i would make is to install that one sensor that goes on the intake tube first before you install the tubes. Damn thing pushed in and i had to take some tubes off.
Anyways... Took it for a short trip. No codes but it felt like it was surging. Will this go away or do i need to adjust something? Oh, i know i read someone adjusted the throttle response with the predator, how do you do that?
Old Dec 31, 2010 | 01:26 PM
  #28
YingYang's Avatar
I will let RIPP chime in on this one.
I had a little surge and RIPP had me crank down on the blowoff. It has maybe 5-6 threads showing, went to 3-4 threads and it helped. I havent messed with the Diablo on the throttle.
Old Jan 7, 2011 | 03:38 PM
  #29
btomike's Avatar
bump.. new question
just got my filter sleeve in and noticed there isn't a whole in it for the vent hose. so RIPP, do i have to cut a whole in it? won't it tear?
let me know ripp...
Old Jan 7, 2011 | 06:24 PM
  #30
RIPPMODS's Avatar
Adjust the BOV to 2-3 threads showing
Make sure you have no vacuum leaks
To adjust the throttle response go to
  • Performance tunes
  • Custom Tunes
  • Select RIPP TUNE
  • Select Modify Custom Tune
  • Agree to Disclaimer
  • Scroll down to Throttle Sensativity
  • Adjust from 10-20% positive
  • Follow on screen directions until key cycle
  • Enjoy
bump.. new question
let me know ripp...
Do you need to run the sleeve all the time, is it that dusty near you? The dust sleeve is intended to be used off-road and you should retain it for that.
But if you want to run it, you could
  1. Elect to source another plastic fitting like the one on the front of the blower and use it on the back side of the air filter. You could also remove the one we provided.
  2. You could drill and tap the air filter induction tube and run it there.
RIPPTECH
