Help!!!
Im in the middle of replacing my rear drive shaft and i cant get the flanges on the axle end to separate. The transfer case end came off with a little pulling (thats what she said). I've been hitting the flange with a rubber mallet and still no luck. Anyone have any tips or tricks???
Thanks in advance
-Joe
Thanks in advance
-Joe
I was able to remove it by inserting a large hex wrench into an unthreaded hole on the differential side of the flange. I then used a pry bar to push between the diff housing and the hex key. By doing that i was able to push the DS out of the flange.
Originally Posted by TheDirtman
Damn, I am glad you cavemen mechanics don't work on my rig. "hit it with a rock and if that dose not work hit it with a bigger rock"
after you drop it off at a PRO SHOP and then leave.
Alright guys, with your advice i was able to get the drive shaft out. Had to use a hand winch and a hammer.
Now im having an issue with the rear pinion nut. What size is it???? does anyone know? I read a write-up on the forum that said 35mm, so i went out and got one, but it seems to be way to big.
