Help!!!
Old Mar 26, 2011 | 11:54 AM
JFRE5H's Avatar
Default Help!!!
Im in the middle of replacing my rear drive shaft and i cant get the flanges on the axle end to separate. The transfer case end came off with a little pulling (thats what she said). I've been hitting the flange with a rubber mallet and still no luck. Anyone have any tips or tricks???
Thanks in advance
-Joe
Old Mar 26, 2011 | 12:22 PM
08yellowx's Avatar
use bigger hammer!! lol it should work if all bolts are out.
Old Mar 26, 2011 | 01:02 PM
JFRE5H's Avatar
bump......
Old Mar 26, 2011 | 01:05 PM
renpia's Avatar
Use a propane torch to heat it up. Should come off then.
Old Mar 26, 2011 | 01:07 PM
KenB1010's Avatar
I was able to remove it by inserting a large hex wrench into an unthreaded hole on the differential side of the flange. I then used a pry bar to push between the diff housing and the hex key. By doing that i was able to push the DS out of the flange.
Old Mar 26, 2011 | 01:13 PM
russcox1's Avatar
you should be able to use just a regular hammer... the metal on metal contact will not damage the flange and the vibration will knock it loose
Old Mar 26, 2011 | 04:44 PM
A/C Guy's Avatar
Put a chisel in between the flanges and strike the chisel with a heavy hammer (2 or 3 lb). Rotate 180˚ and strike again if needed.
Old Mar 26, 2011 | 08:21 PM
915RUBICON's Avatar
Originally Posted by TheDirtman
Damn, I am glad you cavemen mechanics don't work on my rig. "hit it with a rock and if that dose not work hit it with a bigger rock"
Ha ha, so I guess you PAY someone else to hit it with a hammer...
after you drop it off at a PRO SHOP and then leave.
Old Mar 27, 2011 | 05:22 AM
JFRE5H's Avatar
Alright guys, with your advice i was able to get the drive shaft out. Had to use a hand winch and a hammer.
Now im having an issue with the rear pinion nut. What size is it???? does anyone know? I read a write-up on the forum that said 35mm, so i went out and got one, but it seems to be way to big.
Old Mar 27, 2011 | 05:40 AM
Battlefrog's Avatar
That shit was funny....
