Help!!
Old Jun 11, 2009 | 10:08 AM
Hellbound13's Avatar
Default Help!!
I installed a new heavy duty tie rod on my own and now my steering wheel is off center and the esp keeps kicking in. Also the steering no longer returns to center on its own. What did I do wrong? Please help! This is my daily driver!
Old Jun 11, 2009 | 10:10 AM
falconfixer's Avatar
Sounds like an alignment issue.
This might help ya http://project-jk.com/jeep-jk-write-...-end-alignment
Old Jun 11, 2009 | 10:15 AM
greenamphibious's Avatar
yep recenter the wheel.... did you set the tie rod length the same as the OEM one?
Old Jun 11, 2009 | 10:22 AM
bigbluejk's Avatar
did you measure the old one, and adjust the new one to the same length?
Old Jun 11, 2009 | 10:28 AM
seer1's Avatar
Definitely recenter your steering wheel, but before that check your toe-in. Did the same exact thing. I thought I was perfect on setting the new tie rod to the old, but I was off quite a bit when I checked my toe-in. Reset both and it was great.
Old Jun 11, 2009 | 11:10 AM
Yes I measured it as close as I could to stock before bolting it on. I don't understand howit could be so far off. Also I never touched anything on the drag link.
Old Jun 11, 2009 | 12:56 PM
seer1's Avatar
Adjust the toe-in.
