Help!
Old Aug 7, 2009 | 09:15 PM
xpberb's Avatar
Exclamation Help!
installing skyjacker coil lift. front track bar and sway bar wont tighten in. bolts spinning in place. do i need to get it towed into shop???
Old Aug 7, 2009 | 09:18 PM
mkjeep's Avatar
This my sound stupid , but do you have the nut on the back?
Old Aug 7, 2009 | 09:19 PM
mkjeep's Avatar
Or is it not lining up to go though the hole on the trkbar mount?
xpberb's Avatar
theres only one side for it to go on.....and i cant even get the front sway bar aligned to go in...not as big a deal as the others but still
Old Aug 7, 2009 | 09:22 PM
xpberb's Avatar
the two trackbars are in the holes they are supposed to go in but normally the nut would just tighten but the bolt is spinning in place and theres nowhere to grab the otherside of the bolt to stop this
Old Aug 7, 2009 | 09:23 PM
bigbluejk's Avatar
you need to push the axle over... that is why your swaybar is having issues I bet. Try unbolting that trackbar bracket, pushing the axle under the Jeep so it is in the middle of it, then bolt the bracket up.
Old Aug 7, 2009 | 09:26 PM
xpberb's Avatar
alright. but more important. how do i get the trackbar bolts to stop spinning so i can tighten them on so i can even drive it down the road to the local shop....towing costs an arm and leg
Old Aug 7, 2009 | 09:28 PM
mkjeep's Avatar
Rachet strap like this or get someone to turn the steering wheel for you to get the bolt in.
bigbluejk's Avatar
what bolt are you talking about? where the bar itself bolts to the bracket? did it not come with a nut to go on the back? or tell you to re-use the factory nut? I guess I dont understand?
xpberb's Avatar
the bolt is in. the nut on top...when i try to tighten it on. the whole bolt below it turns
