Help me choose some lockers!
Old Nov 9, 2011 | 04:31 PM
  #31
CJ7nvrstk's Avatar
Vet Army
Originally Posted by ECHO
Go Ahead.. do tell
LOL, okay. Broken front end stuff. first an axle shaft that then managed to somehow chew up the lunchbox locker. IMHO, lockers are too tough and lock up a bit violently for the Dana 30. If one feels they must put a traction aid in the front with a Dana 30 I would suggest a Detroit true trac. I also think that the locker puts too much strain on the axle housing and that leads to bent Cs and tubes. That is why I think there are so many guys with Rubi 44s that are bending their fronts. The locked axles cause too much strain.
Old Nov 9, 2011 | 04:35 PM
  #32
StrizzyChris's Avatar
Originally Posted by CJ7nvrstk
ARBs are great until you lose an air line and then you have no lockers. I really felt sorry for the guys I have seen this happen to, on multiple occasions.
Cable lockers... work great as a selectable locker when they work. Worthless when they don't.
Lunchbox lockers, work very well until the added pressure on the carrier causes it to break. Ask me how I know. It happenned to me.
Detroit locker is the way to go.
Leave the dana 30 open unless you want to break on the trail. Again, ask me how I know.
Hope this helps.
Fron my understanding a detoit is great expect you have to make sure your rig is in perfect alignment and tire pressure is exact bilaterally otherwise it puts a lot of on and off strain on the locker. Anyone have any input on if I am correct or confusing this
Old Nov 9, 2011 | 04:45 PM
  #33
mt shawn 37's Avatar
My stepdad has them in his jeep a said the tru tracs also work great in the snow
Old Nov 9, 2011 | 04:51 PM
  #34
c-mack's Avatar
Thank you all for posting! Really helps. So far the true track sounds great! Anybody have any experience with spartan lockers?
Old Nov 10, 2011 | 06:57 AM
  #35
jam0905's Avatar
I don't have any personal experience with Spartan lockers, but they work the same way that LockRight and Aussie lockers work.
Old Nov 10, 2011 | 08:29 AM
  #36
Dynatrac's Avatar
Sponsoring Manufacturer
If you must go lunch box, go Aussie.
Old Nov 10, 2011 | 09:45 AM
  #37
jam0905's Avatar
Why is that?
Old Nov 10, 2011 | 10:57 AM
  #38
Dynatrac's Avatar
Originally Posted by jam0905
Why is that?
Pricing and service level.
Old Nov 10, 2011 | 12:38 PM
  #39
jkellington's Avatar
Interesting...
Old Nov 11, 2011 | 02:55 AM
  #40
CJ7nvrstk's Avatar
Vet Army
For the question regarding tire pressure and the DL.... with any LSD or locker you really need to make sure your preasures are the same from side to side. Actually, rolling diameter is what is important. On a locked or LSD'd axle, if your overal diameter of the tires are different, you can increase the wear (read burn out) an LSD and create unusual lock up/unlock of a locker. So you never want to run different brand tires on a locked or LSD'd axle. (mechanical locked) If you run a short spare and have a flat on a locked axle, you need to move that short tire to an open diff axle or rick damaging your diff.
