Help Me Fix My Problem
Old May 3, 2009 | 12:38 PM
  #21
JKCoyote's Avatar
Default my death wobble fix
stock jk x c-package....installed 2.5" rough country BB...got death wobble anything over 60mph...all parts tight...got cam bolts for adjusting lower control arms....had jeep re-aligned(again) to factory specs(not good as vehicle is no longer "stock")...death wobble now happened at 45-50mph...went to the shop had cam bolt adjusted evenly so it would raise the axle to align better with the front driveshaft....been 2 days now and i'm hitting the highways at 70+mph...back very bumpy roads at 50+...no wobble....just the fix that worked for me...hope it helps others
Old May 3, 2009 | 04:19 PM
  #22
With the added cam bolts does this just help with your caster? I hear cam bolts are not good....Should I go with adj. lower control arm?
