Help need front tow hooks
Old Aug 23, 2010 | 04:47 PM
jeepsta's Avatar
Default Help need front tow hooks
Can I install front tow hooks on factory bumper did not come with do i just cut out the plastic were they should go or not pics if anybody did this please.
Old Aug 24, 2010 | 02:57 AM
ClaytonT's Avatar
Yes, find some factory hooks (which you can probably find on jk-forum), unbolt the plastic bumper cover, cut out the holes, bolt everything back together.
I installed bigger hooks than what would fit at the factory points. I drilled my own holes in between the factory hook mounts. They've gotten a lot of use, but since they are inside the factory mounts they aren't supported as well and bend the bumper if I'm in real deep.
Name:	Bermuda Wedding 130.jpg
Old Aug 24, 2010 | 03:08 AM
WilKJ's Avatar
Vet Army
I have a front bumper with hooks and holes for the fog llights. Mint..., well missing the screws for fog lights (they were rusted)
Not sur eif I should sell it yet...
Old Aug 24, 2010 | 03:17 AM
CJ7nvrstk's Avatar
Vet Army
I did it but no pics, sorry. Yes, you just have to do some cutting and it's a fairly simple install. BTW, you have to cut the inside of the front bumper too, not just that square area.
Old Aug 24, 2010 | 04:34 AM
AFInfidel's Avatar
Did this on the neighbor Jeep girl's JK Sunday, with my old stock hooks.
It's easy, but you have to cut out a decent size chunk of the ABS plastic, so I would recommend a sawsall for the inside of the bumper. A dremel works fine for the outside.
Landmarkbuilder's Avatar
real easy to do, worst part is cutting the back side of the bumper, the plastic is a little thick back there. Where are you at in Michigan? i have a set of front and rear hooks i will sell you for $50. if it isnt too far, might even be worth the drive??
Old Aug 24, 2010 | 11:01 AM
jeepsta's Avatar
Thanks for the help project for this weekend.
Old Aug 24, 2010 | 12:32 PM
SouthJacksonWrangler's Avatar
i'm interested in this as well - anyone got pictures? i would hate to trash up my bumper
