Help with new jeep lift/tires
Old 09-07-2007, 06:32 PM
  #21
jay01th's Avatar
Default lift and 35 37
Originally Posted by jay01th
How much did your 513s cost, and If your adding a ARB locker, would it be cheeper to get the locker and 513s at the same time?? JDJ
Well if you want to go with the minimums, I would do a 2.5 lift and run 35 in tires, or 3 in and run 37 inch tires. In either case, you should take a Re Gear without waiting too long. I think the Gears cost 700 for a set front and back together plus install say 1400?? not sure, and for Lockers 1400 plus install or 3000 installed but not sure?? Maybe go with one locker in rear. JDJ
Old 09-07-2007, 06:52 PM
  #22
Brodmans4's Avatar
Another thing to consider is if you go with 37" tires you will not be able to fit the fifth tire on the stock tailgate carrier. A new bumper with tire carrier will be about $1000.
There are several reasons I suggested the 2.5" budget boost and 35s. The JKs are still new and a lot of new lifts and parts will be coming out in years to come. The 2.5" lift with 35" tires will make your jeep big enough to have to "climb" into it and will give you a chance to figure out if you want to go with a bigger setup. Also, there are a lot of us running 35s with the stock 4:10 gears, and although they slow down the jeep, the 4:10s still work fine on the highway.
Old 09-07-2007, 08:26 PM
  #23
Krypler's Avatar
ok guys i think i have decided to go with 6 in lift and 37's now i know i need to regear and upgrade my drive line will it hurt anything if i do that stuff first and then eventullay do the lift and a 37s later. will it hurt it running it on stock tires with the new gears of 5.13 ?
Old 09-08-2007, 05:22 AM
  #24
T Mac's Avatar
I've never run 5.13's, but my bet is that gearing with stock tires will have your engine revving way above its optimum range. Hopefully someone with more gear-changing experience will weigh in.
Old 09-08-2007, 05:36 AM
  #25
IonZone's Avatar
Wow, in the original post you were looking for how big you could go without "major mods." A 6" lift, new gears and new axels count as major mods in my book. Good luck though.
Old 09-08-2007, 06:30 AM
  #26
JK-Forum Founder
wayoflife's Avatar
You could do it but you're gonna burn a lot of gas.
Old 09-08-2007, 06:31 AM
  #27
JK-Forum Founder
wayoflife's Avatar
I have to agree with IonZone, whatever happend to going as big as you could without major mods?
Old 09-08-2007, 06:38 AM
  #28
Krypler's Avatar
i figured if i am going to do this i might as well do it right. anyone know the height differeance between the 4in with 35 and 6in with 37? i also saw a guys jeep in this forum running a 5.6 lift and 2.5 spacer with 37 with stock 4.10 gears what gives? please help me out
Old 09-08-2007, 06:56 AM
  #29
AndrewZ's Avatar
Get a supercharger and skip the regear...
Old 09-08-2007, 10:08 AM
  #30
Brodmans4's Avatar
You could get a 4" lift with 36" tires and keep the stock axles and gears.
There isn't a "right" way to modify your jeep. Most people change their minds about mods all the time.
I still think a 2.5" lift with 35s will be the best way to go.
Quick Reply: Help with new jeep lift/tires
