Help please. what lift do i have...??
Old Feb 20, 2012 | 05:10 PM
TXCheney's Avatar
Originally Posted by Battlefrog
A lot of people run shocks this way...
OP- I'm also going to say pro comp for the lift...
Yep, thinking that's an es3000 ProComp shock. Maybe a 2.5 or 3" lift.
Old Feb 20, 2012 | 05:32 PM
Kaisoboy's Avatar
Originally Posted by MotiCross
This is the number on the shock... googles it and nothing comes up... really wierd...
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280444"/>
The shocks are Pro Comp ES92450.
The Pro Comp ES9000 is the ultimate nitrogen gas charged shock absorber. With its twin tube design and 10 stage velocity sensitive valving, the ES9000 delivers not only a smooth, comfortable highway ride, but it also enhances off road handling and performance. Engineered for those driving enthusiasts demanding optimum capacity for heavy loads as well as the most demanding driving conditions. It's a 1 3/8" nylon banded full displacement piston head and double welded shock mounts ensure maximum strength and long lasting durability. Choose the Pro-Comp part number you need from the table below:
ES9000 SHOCK SPECIFICATIONS
(Dimensions given in inches)
PART # EXTENDED COLLAPSED TRAVEL TOP MT BOTTOM MT BODY DIA.
92450X 24.84 14.82 10.02 Loop Loop 2.36
Old Feb 20, 2012 | 05:59 PM
MotiCross's Avatar
Thank you do much for the input!
Now that I know the shock, what best replacement coil over I can bolt in instead for a fair price?
Thanks again everyone.
Old Feb 20, 2012 | 06:06 PM
Rancho's Avatar
Sponsoring Manufacturer
Attachment 280444
Pro comp I am guessing.
.stylintrucks.com/parts/pro_comp_es9000_twin-tube_shock_absorber/6303/procompe37924510front.aspx?scid=FROOGLE&ST_SRC=AFF
D'oh a little late to the party.
Old Feb 20, 2012 | 07:01 PM
Quentin_T's Avatar
Read this for gears (pulled from another thread)
Originally Posted by ronjenx
If you want to know for sure, and remove all doubt, do this:
Chock the right rear tire, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jackstand and lower jack.
Put transmission in gear and/or apply emergency brake.
Remove chocks.
Old Feb 21, 2012 | 07:23 AM
MotiCross's Avatar
Thank you , i will definitely try this today, hopefully it works...
Now that i think i know whhat shocks i have, how do i know the height of the lift...?
Old Feb 22, 2012 | 07:22 AM
MotiCross's Avatar
Originally Posted by homeguy
It's for an under the hood light. You can get one from Mopar.
Thank you. i'll definitely look into it.
Also, I still can't figure out what size lift i have... I would like to change my shocks but would probably need to know the size to be able to get the right one... right...?
Old Feb 22, 2012 | 09:02 AM
atomthompson's Avatar
You can always put some extra work into it by disconnecting the sway bar and one end of the shocks, then jack up one side to full stuff and measure from the upper shock mount to the lower shock mount. This should be your collapsed shock length, then drop the axel until the springs are at full length and measure again. That will give you the extended length. Get shocks that are slightly less for collapsed (so your bumpstops do that work for you) and then make sure the extended length is not longer (or your springs might fall out). That should give you the maximum flex.
The collapsed length being shorter is most important so you don't bust them going full stuff. Most shocks reach their extended limit well before the springs, this won't hurt them. This is how I plan on doing mine when I change.
Old Feb 25, 2012 | 10:59 AM
MotiCross's Avatar
So i need new shocks cause these are wayyy too stiff and i need new sway because i still have the stock ones. i'm gonna go with JKS disco.
I can't do anything though untill i know what size i need... is there a way to measure anything to be able to figure this out...??
Old Feb 25, 2012 | 01:10 PM
burbingus's Avatar
To measure your lift height, get a tape out and measure the distance from the top to the bottom of your coil springs. Do the front and the rear. I'll go out and measure mine and let you know how it turns out. Should be able to figure it out this way.
Most probably it's a 2.5 to 3" lift.
Micah
