Help. Pulling left after lift and alignment(s)
Old Dec 22, 2011 | 12:28 PM
Bubbacon's Avatar
Default Help. Pulling left after lift and alignment(s)
Ok. So, put on my full traction 3" premium plus lift (awesome lift by the way). However, every since, my rig is pulling to the left. I've had 3 alignments... And though it's a bit better, the pull to the left is still there. Latest alignment was this morning at tire barn - great service! I have the measurement sheet and there are a couple of tiems to look at... I'm an alignment newb so appreciate feedback from those of you that are subject matter experts!
The leading thought is that the thrust angle (+.13) may be pushing the rig to the right from the rear and thus the front going left. The measurement is technically within spec (green) so I'm not sold on this. The camber on the drivers side front is a little out of spec (-.06), vs the front right of (-.03).
Other thought is that the front track bar may need to be lengthened (they are adjustable)... If so, how do I measure what length should be?
Thanks for any assistance!
Old Dec 22, 2011 | 02:31 PM
cld1371's Avatar
Did you add a new steering stabilzer? If so and it was a gas charge one verus a regular oil base shock, it could pull to the left. When I had mine done, the steering stabilzer was replaced by a bilstein gas charged shock. The alignment is 100% perfect but it pulls to the left.
There is a test. jack up the front of the jeep with both tires off the ground. If it naturals turns to the left, then it probably your answer.
Old Dec 22, 2011 | 02:32 PM
SaharaTodd's Avatar
Is it pulling or is the wheel off?
Old Dec 22, 2011 | 02:50 PM
JayRud's Avatar
Man! I have been wondering about this. Mine has a slight pull left after installing my bilstein stabilizer. It's irritating me enough where I might put my stock one back on. Thx for your post.
Rick in Colorado's Avatar
Has the same experience with the Bilstein - replaced it with OME and it's now fine. It is more prevalent on 2-drs.
Old Dec 22, 2011 | 02:52 PM
RubiconRod's Avatar
I have the same lift and same problem. But I have the bilstein SS which is the cause of mine pulling left.
Old Dec 22, 2011 | 02:57 PM
d1gt-x8's Avatar
This just happened right now... Look under the rear left shock by the track bar.. My bolt fell off
Old Dec 22, 2011 | 05:24 PM
Bubbacon's Avatar
As a matter of fact, yes... Blistein stabilizer. But a stabilizer shouldn't affect this ?!?.
One way to check... I'll put the stock back on tomorrow and try it out. Hmmmm
Old Dec 22, 2011 | 05:27 PM
RubiconRod's Avatar
Originally Posted by Bubbacon
As a matter of fact, yes... Blistering stabilizer. But a stabilizer shouldn't affect this ?!?.
It does. Tons of threads on the bilstein pushing you left... I've kind of gotten used to it but annoys me at times.
Old Dec 22, 2011 | 05:29 PM
Bubbacon's Avatar
Thanks. This sucks. If the blistein is the cause, what stabilizer have others switched to?
