Help with Shocks!!
Old May 19, 2015 | 02:18 PM
JKLove's Avatar
Veteran: Marine Corp
Originally Posted by nthinuf
Since you have RC shocks, it's probably a good bet that you have a RC lift. Once you post a few pics we can probably point you at the exact lift on their website.
While you are taking pics, get one of the pitman arm and the upper trackbar bracket (to see if you have a drop pitman), the front control arms (to see if they are stock/fixed/adjustable), and the bolt at the axle end of the front lower control arms (to see if you have cams).
Thanks so much! Take a look at the pics I just posted. If I need to send more detail, please let me know.
Old May 19, 2015 | 02:24 PM
JKLove's Avatar
Originally Posted by Invest2m4
Best way to measure lift is using the factory measuring points and seeing how much you differ. See pics.
Attachment 611445
Attachment 611446
Assuming I measured correctly, it looks to be stock?
Old May 19, 2015 | 02:25 PM
jeepmojo's Avatar
Default love the rancho
rs 9000xl Great ride from them. You wont go wrong getting them . Improved my jk ride 100% over stock shocks.
Old May 19, 2015 | 03:00 PM
nthinuf's Avatar
Originally Posted by jaxhammer
Lol, the shock says rough country. Guess that tells you what type of shocks they are...
Is that a spacer on top of the coil? Look on their website at the 1.75" and 2.5" spacer lifts. If it's the 2.5", it should be pretty easy to compare the components to what you have.
Old May 19, 2015 | 03:12 PM
Rancho's Avatar
Sponsoring Manufacturer
Yep looks like a spacer there.
Old May 19, 2015 | 04:40 PM
Invest2m4's Avatar
Looks like the factory isolator to me. And based on the measurement, hard to believe the coil sag is that bad.
Old May 19, 2015 | 04:53 PM
JKLove's Avatar
After comparing what is there to photos of an isolator and/or spacer, it looks more like an isolator. Given that it is the isolator, should I be concerned about the coil sag?
Old May 19, 2015 | 04:55 PM
JKLove's Avatar
It looks like an isolator as 2M4 stated below. I just want to replace the back shocks. Can I do that without replacing the front too?
Old May 19, 2015 | 05:02 PM
nthinuf's Avatar
Call them, or PM their forum rep. From past posts, they seem pretty good about replacing anything that fails.
Old May 19, 2015 | 11:08 PM
lowendrider's Avatar
Looks like a spacer above the factory isolator to me.
